Ferrari 0855 Ellena | Page 18 | FerrariChat
Ferrari 0855 Ellena
Discussion in 'Vintage (thru 365 GTC4)' started by enio45, Sep 23, 2014.
  1. omd78
    omd78 F1 World Champ
    Dec 26, 2005
    13,242
    Breda, Netherlands
    Martin
  2. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    More jewelry add to the engine compartment.....
    I got a pumping issue i need to solve. I don't have a thermostat that is on the motor, so that means it has to go into the
    upper rad hose system. My thermostat housing i have does not allow enough room for the housing, the water pipe etc
    to all fit?? Historial photos are all over the place as far as to what is correct. the housing i have has the 2 level - meaning output from the rad is 2 inches lower than the input, which is fine, but now the pipe going from the housing to the motor is too tight to fit appropriately. May have to make a pipe....need some advise
    colombo2cam likes this.
  3. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Ill get some better pics today to demonstrate the delima
  4. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    951
    Arizona
    Jim
    I've seen one period photo in Road and Track of an inside plug PF coupe without a thermostat in the upper hose. I've seen one high end restored series 1 without a thermostat too. The stepped thermostats I have seen tend to be on cars earlier than yours in my observations. I have typically seen the straight thru thermostats on cars just after yours. So I think all three are viable options. On my car and it sounds like yours too, the stepped thermostat would not fit. I ended up using a straight thru thermostat but I have never liked the fact that the flanges on the thermostat are bigger than the radiator and the pipe. I have the same radiator as you and have wondered if the correct way is no thermostat in the upper hose and only have the thermostatically controlled blinds in the front that you have. I know at first it didn't seem like mine was going to work either, but after a few tries I got it to work with the straight through thermostat. I suspect yours will too.
    Cheers Jim
  5. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    jim, sounds like i need a visit up your way......
    also - i tried to get my louver system to work by inserting the louver thermostate tube in water to see if it moves the bell crank on the radiator. Unfortunately i could not get the tube thermostat to move. Are these replaceable/available?
  6. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    Ed, is it made so it can be taken apart?
    john
  7. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    does not look that way - seemed to be soldered on the bottom - i guess if it done work, i can try to unsolder the bottom section
    seems to be stuck open, when installed, the louvers are wide open
  8. John Vardanian
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    #433 John Vardanian, Dec 3, 2019
    Ed, I'd think that there is a coil spring inside the cylinder and it's binding. I would be tempted to take it apart.
    It's probably not a dependable system or Ferrari would not have switched to the complicated and costly manual curtain.
    john
  9. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    ok, i have another spare one so ill attempt to unsolder this and see what i see.....
    so what do the big boys do when they have this issue? Guys like Motion and GTO?
    one interesting thing with mine is that the plunger is stuck open so the air flows thru - i could leave it that way
    and watch it, if it ever changes......at least i would not be in an overheat situation
  10. GBTR6
    GBTR6 Formula Junior
    Dec 29, 2011
    453
    Titletown, USA
    Perry Rondou
    Just stopping in checking on your build. That is a beautiful car, love the colors, inside and out. Lots of work, but a great sense of accomplishment in doing it all. Congratulations on the progress and on finishing to enjoy it.
    Perry
  11. John Vardanian
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    Ed, call Mel and Sons in Concord, CA. It looks like an ordinary radiator shop, except it's not. I've seen some exotic radiators there in my visits. They may give you a lead or maybe tell you the fix.
    john
  12. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    will do - so far nothing - i was told that there is a spring in there plus butane????? i don't know.....tempted to open it up
  13. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
  14. colombo2cam
    colombo2cam Formula Junior
    Jan 31, 2019
    840
    Ted
  15. NYC Fred
    NYC Fred F1 World Champ
    16,244
    Fort Lauderdale, FL
    Fred C
    I love the top rear cutline of the doors...along with everything else...
  16. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Thank you......
  17. clucchini
    clucchini Rookie
    Aug 7, 2017
    5
    Indiana
    Christian Lucchini
    Hi Ed,
    If you like I can resend over that contact I had a from work that may be able to help?
  18. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Hey Chris - yes send to my email pls!!
    Thank you!!
  19. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    C50, colombo2cam, Boudewijn and 3 others like this.
  20. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    #445 enio45, Dec 15, 2019
    The plate is just sitting on the bumper for looks - it is large but the back tail panel can handle it
    This plate is interesting - i have the front as well - the only providence in italy that spells out the city name
    I had to buy the whole car when i was living in Milan, registration and all to get this plate - very rare do you see a ROMA plate for sale. It was at one of the Mosta Scambio's in Milan at the time.
    I thought the 7007 was cool - BOND, JAMES BOND!!
  21. Bryanp
    Bryanp F1 Rookie
    Aug 13, 2002
    3,822
    Santa Fe, NM
    I don't know if you have ever seen the personalized Virginia license plate that Gordon Stewart has had on his Boano for ages (I think he still owns it) that always made me chuckle - "TDF PARTS"
    You are so close! It looks fantastic!
    Thomas Magnum likes this.
  22. enio45
    enio45 Formula 3
    1,652
    Gilbert, AZ
    Ed
    Yes i do know Gordon's car and his license plate - very cool.
    He does still have his car.....nice car!
  23. fiatosca
    fiatosca Formula Junior
    Feb 20, 2013
    417
    Bloomfield Hills, MI
    Bob B
    Favorite thread on FChat. The care and sensitivity to detail is inspiring. What a lovely automobile.
    GIOTTO and colombo2cam like this.
  24. jcavalie
    jcavalie Formula Junior
    660
    Oakland, CA
    Jim
    It looks a*m*a*z*i*n*g !!!
  25. gimmea250swb
    gimmea250swb Formula Junior
    585
    Washington, DC
    Taylor
    Dad's got quite the sense of humor :)
    Ed, it looks absolutely amazing - I hope to see it in the flesh!
    colombo2cam, fiatosca and readplays like this.
