Ferrari 1980's ignition coil connector rubber boot. | FerrariChat
Discussion in 'Technical Q&A' started by 360modena2003, Mar 15, 2022.
  1. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,460
    Hello,
    Any suggestion on how to replace/repair this?
    I believe the boot could be found, but I think it would be risky to de-pin the connector. Image Unavailable, Please Login
    Sent from my MAR-LX1M using Tapatalk
  2. wmuno
    wmuno Formula Junior
    522
    Wilmette, Illinois
    Bill Muno
    I suggest buying a can of black liquid vinyl (Plasti Dip or Liquid Tape) and painting an even coat over the top of the entire boot.
  3. Rifledriver
    37,288
    Taking the connector apart and back together is not a great big deal. It may take a trip to the electronics store to buy one of the several special tools for the job. See if you can get the boot. Lots of people here can talk you through taking the connector apart.
  4. tbakowsky
    Sep 18, 2002
    20,044
    The Cold North
    Tom
    Look on the Porsche forums. The 928 used a similar ignition module and connector boots..
  5. Llenroc
    Llenroc F1 Veteran
    5,565
    Colorado
    Vern
    In addition to what RD is stating; here is a pic of type tools to use, the red handle one is what I have used to remove the pins from a similar plug. The other is an example of a tool you might find at an electronic store and will work also. In the pic are 2 boots that I have, they are 46mm and the smaller one is 39mm, not sure which you would need. you are welcome to have these; send me a PM with your address and I will send to you. The pins are easily removed, there probably is a youtube vid on the process.
  6. 360modena2003
    Jul 11, 2009
    2,460
    Thank you very much. PM sent.
  7. raemin
    raemin Formula 3
    Jan 16, 2007
    2,389
    Lyon (FR)
    R. Emin
    This connector is not the usual fastin faston seen in our cars, but the boot lolks like a TE. As you do not have access to digikey (US) or TME (Europe), you may try 3waycomp in the Uk
    https://www.3waycomponents.co.uk/Automotive-Connectors/Timer-Connectors/Timer-Connector-Kits-With-Boots/7-Way-TE-Junior-Power-Timer-Black-Wiring-Connector-Kit-With-Boot
    (note that their ebay store provides cheap shipping).
    As far as the connector is concerned it's a no brainer to me: I cut the harness and replace the whole connector.
