Ferrari 308 2V Engine Build | FerrariChat
Discussion in '308/328' started by ItalianProjects101, Feb 5, 2023.
  1. ItalianProjects101
    Feb 5, 2023
    215
    D
    Hi Y'all,
    I have a dismantled 1978 Ferrari 308 2v per cylinder carburetted engine which I'm attempting to build. I would like some advice as to what small modifications (which can be retracted) that can give a nice hp and reliability gain, of course without braking the bank.
    I have 2 other Italian cars, which I have modded (nearly to race spec) one of which is currently in the process. It's an Alfa Nord engine. On that car I am not too concerned since complete engines are fairly cheap, however a Ferrari V8 is certainly not.
    Any thoughts?
    Thanks!
  2. Rifledriver
    37,089
    Cheapest horsepower during a rebuild is to go to 10 or 11:1 compression. They respond well to it and you need pistons anyway.
  3. ItalianProjects101
    Feb 5, 2023
    215
    D
  4. George Vosburgh
    George Vosburgh F1 Rookie
    Du_Man, beng and waymar like this.
  5. ItalianProjects101
    Feb 5, 2023
    215
    D
    Anything else which is recommended such as a particular regrind on the cams?
    P.S. The engine is out of a US spec car
  6. topcarbon
    topcarbon F1 Rookie
    Nov 3, 2006
    2,605
    update the engine management system
  7. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
  8. topcarbon
    topcarbon F1 Rookie
    Nov 3, 2006
    2,605
    I have j&e pistons in mine
  9. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    628
    Massachusetts
    Joe
  10. ItalianProjects101
    Feb 5, 2023
    215
    D
    I'm a noob and still quite reading alot about the engines in these cars, however I was under the impression the ECUs where only used in Fuel Injected cars. Is this not the case? I thought carburatted cars use 2 distributors. At least thats what my photos show.
  11. ItalianProjects101
    Feb 5, 2023
    215
    D
    Oh wow, I did a rigorous search for their name along the keyword "Ferrari" and nothing came up prior to me posting their link. Now I am just browsing in other car communities and I'm blown away as to what others have stated Gazzella are doing. I'll certainly be staying away from them
  12. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,020
    Early 308GT4 cams (Ferrari factory recipe) ?
    BigTex likes this.
  13. ItalianProjects101
    Feb 5, 2023
    215
    D
    I read about those on another thread. I believe according to a post by @Ferraripilot
    The early GT4s through '77 had the same cams as Euro spec cars and 76-77 US GTBs which is as follows:​
    intake: 235 dur @ .050 with .352 lift
    exhaust: 225 dur @ .050 with .329 lift​
    The US '78-'79 cars (GT4s and GTS/GTB) were subject to the following due to emissions:​
    intake: 217 dur @ .050 with .305 lift
    exhaust 212 du @ .050 with .300 lift​
    I was wondering if they would be the best approach or if some aftermarket alternative would be better. Furthermore if they have any particular code for me to try and find to buy them
  14. BigTex
    79,368
    Houston, Texas
    Bubba
    The 1978 cams will need to be reground to the "1975 thru 1977" higher lift profile, with maybe a few modern ramp advancements.
    The original 8:1 pistons stopped well below the engine block deck, so the modern ones will fit "beter"
    The oil Burners of 1980 to 81 used up every Ferrari 308 piston in the world, so here we are!!
  15. ItalianProjects101
    Feb 5, 2023
    215
    D
    Do you know from where I can acquire the cam specs to regrind my cams?
  16. BigTex
    79,368
    Houston, Texas
    Bubba
    For 1975 thru 1977, 308GT4 engines and 308GTBs were exactly the same, save for market variances on specs.
    He has said he has a 1978 twin distribitor car, so I'm assuming North American spec, but the 1978 versions fitted Catalytic convertors so they backed WAY off on the cam ramps and lift.
  17. BigTex
    79,368
    Houston, Texas
    Bubba
    Damn, it's a West Coast vendor.......someone will post it up.
    Anyway your four cam sticks can definately be modified.
    Avoid the Legendary "P6 LeMans specs" as it gives you an undrivable peaky motor, for street use!
    For me, I 'd order replica 1977 NON CAT stickers for the door jamb and engine compartment and hang an ANSA.
    Of course that's illegal advice if you are in Cali!!!
  18. ItalianProjects101
    Feb 5, 2023
    215
    D
    Yes it is American spec. I will be removing the cat and all the other nonsense since where I'm located they are not necessary. I intend to rebuild the engine to EU spec with some new and improved technology, such as high comp pistons etc
  19. BigTex
    79,368
    Houston, Texas
    Bubba
    Any Factory Info of the 1975 thru 77 specs is a good starting point, really.
  20. BigTex
    79,368
    Houston, Texas
    Bubba
    They are so old now, "No ONe cares" except for cali..LOL
    Mine actually passed Smog here before going exempt, but you heated the engine and exhaust full temp and left it running until they sniffed it for unburned HCs
  21. BigTex
    79,368
    Houston, Texas
    Bubba
    There's actually a 12V electric retrofit of the o2 injection nozzles.
    You need to examine the nozzles in the head as many of them have totally melted or colapsed
    The Chevy Air pumps off the cam are just a "bad idea"...IMO
    Welcome BTW!
    I 've had three, earlier than yours..
    20405
    22127
    22641
  22. ItalianProjects101
    Feb 5, 2023
    215
    D
    Can you send me a link to this thread? What exactly is the purpose of these?
  23. Rifledriver
    37,089
    Garbage.
    Put Wossners in it.
    JE hasn't made a decent piston in 25 years.
    BigTex and Ferraripilot like this.
  24. Rifledriver
    37,089
    There is a boatload of advice being handed out around here by people who have never so much as taken off a valve cover. There is already a lot of bad advice in this short thread. Be very careful who you listen to. Ferrarichat is loaded with clueless keyboard warriors and self appointed experts.
    Good luck.
    Llenroc likes this.
  25. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,846
    Atlanta
    John!
    I am not sure of the early part number stampings on early cams as I've seen them marked a couple different ways, yet they're all early cams. Frustrating as it almost makes the only way of identifying them is having them in your hands.
    If all you want to do is swap to early spec cams, you could have your emissions spec cams reground to a different lobe profile that's close or even a bit better than the early spec cams as these heads can take a bit more lift. Max lift before you start running into valve guide issues is about .420 but I wouldn't push beyond .390 or so with stock springs. Lots of great cam grinders around. These cams don't have much of a base circle meaning it will have to be back cut a tiny bit and you make up the difference with valve shims that are usually .030-.040 thicker, which are available. Bullet cams post their cams master list and have all manner of profiles that would work well.
    Cat Cams in Belgium make great cams and can do an early stock Euro profile, or their sport profile but you need to increase compression for those. A bit pricey
    The cams I am often curious why Ferrari never used them in 308s is the Dino/Daytona profile. That's a fabulous cam with 252 duration @ .050 and about .370 lift if I remember right. It's made for adding compression too, works great.
