Ferrari 308 - A/C Recharge | Page 2 | FerrariChat
Discussion in '308/328' started by robo330, May 24, 2018.
  1. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Here is a picture of what I am looking at. The lower port has "Suction" cast into the housing. Is that what I should go by for High Side and Low Side, or Upper and Lower...? The can of R134 will not hook up to either of these ports!!!
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I believe those are r12 ports on the compressor.
  3. rjlloyd
    rjlloyd Formula Junior
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    Yes those ports in the picture are R12 ports. For reference “low side” is “suction” “high side “ is “discharge” screw on aluminium adapters are available to convert r12 ports to 134. From memory the suction adapter screws straight on without any changes required. The discharge adapter has a Schrader valve built into it and requires the existing valve to be unscrewed from the r12 discharge port
    StuR likes this.
  4. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Where do I get these? From a A/C place or
  5. rjlloyd
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    Readily available on eBay, any automotive a/c supplier and I would think most workshops that do auto a/c would have them. Not expensive
  6. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Stop for a moment and realize that you think your system is R134, but we're seeing R12 ports.
    You need to do more than just find a screw-on adapter.
  7. moysiuan
    moysiuan F1 Rookie
    4,098
    Canada
    Yes, if you have a 134 conversion whoever did that would (should?) have installed the required R134 fittings on the compressor. It seems likely you still had the old R12 freon in your system.
    Fyi, the conversion requires flushing the system to get the R12 oil out, which is not compatible with the R134 oil. Old orings on various fittings are replaced with the green type which are 134 compatible rubber. The dryer is typically changed out, and 134 charge fittings installed on the compressor. The really thorough conversion would also replace the hoses with barrier hoses, the 134 will diffuse through the old style rubber, although many do not do this an accept the diffusion leakage and top up every few years. You need an ac shop with flushing equipment to do this properly, although you can buy aerosol cans of flush, new 134 oil, change o rings and charge yourself if you are an ambitious diy type.
  8. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
