Ferrari 308 Air Pump & Pulley Removal - Cover needed | FerrariChat
Discussion in '308/328' started by ItalianProjects101, Dec 5, 2023.
  1. ItalianProjects101
    Feb 5, 2023
    215
    D
    I am currently rebuilding my engine on my 1978 308 GTS (US Spec) and part of the rebuild, is that I want to eliminate the emissions (I can do this where I am located since the car is over 30 years).
    I will be replacing the stock camshafts with a set from CatCams so I'm wondering what is the correct (not just visual but also technical) to cover the endplate.
    Upon my research I found out that Euro spec cars had a blow by cover which was plumbed to the bell housing.
    On the US car however I can see that on the bell housing there is also this pipe but unsure to what it is plumbed to:
    Is the below photo from another thread I found correct? It plumbs to the cylinder head?
    If that is the case, I presume just an endcap would be enough correct? I noriced Carobu did the following:
    Would a stock euro left side cylinder head camshaft end plate cover work on the right side US cylinder head?
  2. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    747
    Omaha, NE area, US
    Steve
    #2 bitsobrits, Dec 5, 2023
    It's the correct size, but the air pump cam cover and the cylinder head both lack provision for fasteners to hold it in place.
    To accomplish this on my own car, I changed out the cam cover for a euro spec one (has the required holes, and no lumpy mounts for the air pump), then drilled/tapped the head (!) to install studs to hold the new cover. So not a trivial undertaking. Btw, the engine was out at the time. Would be very difficult with the engine in. FWIW I used the vented to the crankcase cap arrangement.
    A better/easier solution might be to have a custom plug machined you could seal into place where the cam seal formerly resided. Much easier to do with the engine in situ.
  3. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
    That's a simple part to get machined. Cost is usually the bugger for one off parts.
    Round cap with a step for an o ring like the later QV cam front seals. Held on place via tension of the cover.
