Ferrari 308 cam belt drive pulley removal | FerrariChat
Discussion in '308/328' started by ItalianProjects101, Sep 9, 2023.
  1. ItalianProjects101
    Feb 5, 2023
    215
    D
    Photo for reference. How do you remove these pulleys from the shaft?
  2. Steve Magnusson
    26,826
    That's not a stock drive sprocket nor center nut (but that shouldn't make any difference). Remove large center nut, remove sprocket (using small puller carefully, if necessary).
  3. ItalianProjects101
    Feb 5, 2023
    215
    D
    That's not mine. Found on the internet for reference. Mine is:
  4. Steve Magnusson
    26,826
    Well, can agree that that's a "project"...(but same response: remove harmonic damper, remove center ring nuts, remove cam drive sprockets)
    waymar likes this.
  5. ItalianProjects101
    Feb 5, 2023
    215
    D
    Oh it is a project all right ahha! See my other thread!
    My question is how to remove the sprockets from the cam gears? I tried having them pressed out with a hydraulic press and they moved a little than didn't budge at all with 1 ton or so of press. Didn't want to over press and damage something.
    I was applying pressure to the top of the "bolt" i.e. the shaft so that the sprocket is seperated from the pulley
  6. Steve Magnusson
    26,826
    Don't follow you here -- the "pulley" and the "sprocket" are the same thing ("pulley" is more often used for rotating belt components without teeth; "sprockets" are rotating belt component with teeth). Are you supporting (i.e. pulling) the "pulley/sprocket" at its rear surface, and pressing on the end of the shaft? Do you have the whole front cover assembly removed from the engine block?
  7. ItalianProjects101
    Feb 5, 2023
    215
    D
    I am apply pressure at the top of this where there is the thread, so this pops off and by implication the sprocket/pulley is removed. Of course the top nut has been unscrewed
  8. Steve Magnusson
    26,826
    We're not communicating very well. What year 308? Do you have a copy of the Mondial 8/QV WSM? If not, see Fig 27 page B37 here:
    https://www.dropbox.com/s/z99soo68ny9n2qa/Mondial8qv_workshop_281-83.pdf?dl=0
    If you have the whole front timing assembly off of the engine block, and are pushing on the end of the shaft while supporting the front timing cover casting = not so good as this will put a lot of force on the snap ring behind the outer ball bearing and may damage the snap ring groove in the casting.
    If you are trying to remove the cam drive pulley from the shaft with the front timing cover still in place on the engine = you must support (i.e., pull) the backside of the cam drive pulley when pressing on the end of the shaft.
    Please be more specific about what you you are trying to do rather than posting pictures of the individual parts.
  9. ItalianProjects101
    Feb 5, 2023
    215
    D
    I think this is easier to follow, this is my video of what I'm trying to explain:
  10. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    I wouldn’t do that, I would just use a puller to pull the sprocket away or off the shaft instead of pushing the shaft down away from the sprocket.
    waymar likes this.
  11. ItalianProjects101
    Feb 5, 2023
    215
    D
    It's not budging, with a puller like this:
  12. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
    The woodruff key will prevent the shaft from moving thru the lower pulley as it binds to the bearing behind it and is of course held captive in the pulley. So your setup with the press is a no-go.
    You'll need a puller like the one you posted. If it's held fast.. then apply heat to the pulley via a torch and maybe some penetrating oil or candle wax.
    Steve Magnusson and fatbillybob like this.
  13. fatbillybob
    Aug 10, 2002
    29,033
    socal
    Lots can be learned from the parts diagram. Then you can see what needs to be removed.
    smg2 likes this.
  14. Steve Magnusson
    26,826
    As SMG said, it can't be done that way (I forgot about the woodruff key not being able to pass thru the ID of the outer bearing). You'll have to "pull" the cam drive pulley off the shaft.
  15. dino1971
    dino1971 Karting
    156
    Bordeaux, France
    Dario
    Hi, I also had trouble getting them off. I tried the one you have in the photo, and it was not strong enough to budge them. I the used a puller that I made by welding together some steel bars and pieces from a beefier puller that I have. Some heating was also applied, but not too much to avoid damaging the parts.
    Good luck, and be patient!
    PS, I thought that you were much more along in the rebuild judging from the photos in your rebuild thread.
  16. ItalianProjects101
    Feb 5, 2023
    215
    D
    I got them off cheers for the pointers guys much appreciated :)
    dino1971 likes this.
  17. ItalianProjects101
    Feb 5, 2023
    215
    D
    I am indeed more along, I need to update that thread a little more haha! That is why I am starting on the small "parts". I needed to take these off so I can take them for media blasting and having them finished in black oxide coating.
    Currently, I have had the heads pressure tested and hence we started with redoing the valve seats and resurfacing the heads. The block is fully stripped down, with the liners out and they are also getting honed. The crank has been polished and didn't need any regrinding!
    Essentially now waiting on the machine shop (hopefully in a few weeks time everything will be ready) and waiting for the remaining parts to arrive.
    Whilst I'm waiting on the machine shop I have started rebuilding the callipers:
    However can't continue any more since I'm waiting for parts to arrive.
    Aiming for end of year to have it running!
  18. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Use soda blasting to save having to remove all the plugs to clear out the media. You’ll have to drill out some plugs. I vapour blasted some heads this year— they looked great but the extra time to remove plugs, clean lots, new plugs was a pain.
    Tonksy1 likes this.
  19. ItalianProjects101
    Feb 5, 2023
    215
    D
    I'm only going to soda blast these pulleys/sprokets. The heads and block I'm going to vapour blast
  20. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I’d do it the other way round. The pulleys have no internal oil or coolant passages so blast them with anything. Use soda for the block and heads. Vapour blasting has abrasive media that will reach every crack, crevice, and passage.
  21. ItalianProjects101
    Feb 5, 2023
    215
    D
    My mistake, I meant ice blast the heads/block. These pulelys are gonna get soda/sand blasted.
  22. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    If your lower pulleys are pitted you could ask on here for a good used pair as I’ve sold a few of those round-tooth sets in the top photo so some may have their old ones sitting in a box.
