Ferrari 308 dry sump front cover problem | FerrariChat
Discussion in 'Technical Q&A' started by snowsports1, Nov 23, 2019.
  1. snowsports1
    snowsports1 Formula Junior
    Jan 31, 2013
    918
    Brian
    Hi guys, today’s not a good day, I’ve converted a wet sump 308 engine to dry sump. One of the biggest challenges is making the changes to the wet sump front cover to create an oil pipe boss. A friend did this for me and he did a good job but I’ve had problems sealing the banjo oil pipe to this housing which meant many test fits / removals. It’s a long storey but I’ve managed to cross thread the housing now fitting the banjo. Has anyone else managed to repair the threads on this housing? I really don’t want to take the engine out again
  2. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,318
    Germany
    Steven
    sorry for your trouble. cool project!
  3. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    Helicoil insert?
  4. snowsports1
    Jan 31, 2013
    918
    Brian
    I’m not sure if that’s possible it’s M26, anyone got experience repairing these threads?
  5. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
  6. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    Yes I can
    this is the same cover-essentially-as is used on 288/F40 engines...
    Its strictly a T and M affair
    Is it aluminum alloy-or mag alloy-this is a big deal-both effort and cost wise....
    Dis you square every thing when machining the base components-oir, was this an "insitu" mod?
