Ferrari 308 Fuel Tank Coating and Engine Bay Colour Code | FerrariChat
Discussion in '308/328' started by ItalianProjects101, Sep 16, 2023.
  1. ItalianProjects101
    Feb 5, 2023
    215
    D
    Frisky likes this.
  2. kiwiokie
    kiwiokie Formula 3
    1,539
    Tulsa, OK
    John McDermott
    I don’t know the exact factory products but I was able to get the stippled heat coating using a product called lizard skin and POR15 high temp aluminum is a decent approximation for the original silver but more a satin than a matt finish.
    Du_Man likes this.
  3. ItalianProjects101
    Feb 5, 2023
    215
    D
    So hand painted? Did you strip tehn down to barr aluminum?
  4. ItalianProjects101
    Feb 5, 2023
    215
    D
    Also did you apply some under coat or does this paint leave this “lizard skin” finish?
  5. kiwiokie
    kiwiokie Formula 3
    1,539
    Tulsa, OK
    John McDermott
    I just patched the areas where the thermal coating had chipped away. Lizard skin is a separate product. It is a thick goo that can be applied and stippled to look like the factory coating. The por15 is the top coat to give the silver finish.
  6. kiwiokie
    kiwiokie Formula 3
    1,539
    Tulsa, OK
    John McDermott
    Be careful to not add additional thickness where the steel tank straps pass as they are a bear to get threaded. At least they were on my GT4.
  7. cstorry
    cstorry Karting
    Apr 28, 2005
    87
    Ottawa, Ontario
    Chuck Storry
    Not to go too far off on a tangent but should all 308s have a silver pebbled firewall ?
    My tanks are silver but the "firewall" is black. I have tried to do a closer inspection without removing the engine but its hard to see if it was originally silver and a previous owner painted over it?
    (1985 308 GTS QV - non-USA model - Italian market car sold in Rome) Image Unavailable, Please Login
  8. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,129
    Mansfield, TX
    Ron
    Same year QV sold in France and original color of the firewall is silver. I suspect someone painted yours.
    cstorry likes this.
  9. ItalianProjects101
    Feb 5, 2023
    215
    D
    My engine is out so I have PLENTY of room to paly around hence why I'm restoring my entire engine bay but cheers for the input
