Ferrari 308 (GT4) Used Parts | FerrariChat
Discussion in 'Ad Archives' started by samsaprunoff, Jul 5, 2015.
  1. samsaprunoff
    samsaprunoff F1 Rookie
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    #1 samsaprunoff, Jul 5, 2015
    Good day All,
    Just cleaning out my shop...
    These parts were off a 1976 308 GT4 USA Version and are all used:
    One (1): Air Injection Tube with Check valve
    One (1): Oil Radiator Line (top)
    One (1): Oil Radiator Line (bottom)
    One (1): Front Bank Divertor Valve and mounting bracket
    One (1): rear Bank Divertor Valve and mounting brackets
    Four (4): Metal Camshaft Sprockets with pins
    I also have a good used (and was working) Front bank Cylinder head. Sadly, the head has been disassembled and so a rebuild would be suggested. I will provide pics over the next several days.
    Cheers,
    Sam
  2. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    #2 samsaprunoff, Jul 5, 2015
  3. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    #3 samsaprunoff, Jul 5, 2015
  4. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    #4 samsaprunoff, Jul 5, 2015
  5. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    #5 samsaprunoff, Jul 5, 2015
  6. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    #6 samsaprunoff, Jul 5, 2015
  7. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    #7 samsaprunoff, Jul 5, 2015
  8. BigTex
    79,380
    Houston, Texas
    Bubba
    Those air lines and valves would be solid gold, to a California resident trying to smog any 308!
    GLWS!
    Nice cam gears too!
  9. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    Good day BT,
    Indeed, I thought that these items would be helpful to someone needing to restore their GT4 to original USA spec... and/or needing to comply with CA emissions. I am sure I have the other air rail too.... I have to keep digging in my parts boxes. It is actually quite shocking what one accumulates over time... I guess I have reached that age where one stops acquiring and starts dispersing :)
    Thanks again for your positive regards!
    Cheers,
    Sam
  10. BigTex
    79,380
    Houston, Texas
    Bubba
    You don't have to tell me!
    I have seven front turn signal lenses, and TWO clocks!
    Why remove the metal cam gears?
    Did you go with newer ones?
    I need to check, and make sure mine are not plastic fence versions...
  11. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    Good day BT,
    Way back when I had a complete spare 308 GT4 engine when I had my GT4. Over time, when needed, I used the parts for my GT4 and when I sold my GT4 I started selling the remainder of the spare parts. I sold the Camshafts a while back which then left these sprockets.
    Cheers,
    Sam
  12. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Keith Mitchell Wintraub
    Hi Sam:
    Sorry to hijack this thread but your inbox is full so I can't send you a PM.
    Are you still planning to build another round of 308 fuse boxes?
    If so, what's the status?
    Keith.
  13. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Keith,
    Indeed it is best to keep the Fuse block questions, etc in the FuseBlock thread in the Boxer section so as to not splinter the info... I will post the update there, as there has been progress.
    As for PMs...I rarely check them and so it is best to send me a direct e-mail, as I get those directly and promptly.
    Cheers,
    Sam
  14. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,294
    Ventura, California
    Robert Garven
    any GT4 tools, jack or books?? :)
  15. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Robert,
    Sorry... just parts that one would find off an engine... and even those I am nearing the end of having.
    Cheers,
    Sam
  16. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    Good day All,
    Cam Sprockets are now sold.
    Cheers,
    Sam
  17. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
  18. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
  19. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    #19 samsaprunoff, Jul 18, 2015
    Ferrari 308 Used Cylinder Head (Rear Bank / Right) with matching valve cover and oil filler Cap
    - Ferrari Stamped Part: 103514, Valve Cover: 105002 (supercedes to 107112), Oil Filler Cap: 103939
    - Bare Head, although I do have a box of parts (springs, valves, etc that will go with the head).
    - This was a good used head off a 1976 308 GT4 that suffered a valve failure on the Front Bank... the rear bank (this one) was fine. Rebuilt replacement heads were found and so both were replaced leaving this one.
    - All of the valve seats look excellent. There is one small dent/nick/chip located in the adjacent to cylinder 1's intake valve and this is indicated in the picture.
    - Overall given the age of the head it should be considered as an excellent (light) rebuilt candidate.
    - Price: $650 USD + Shipping
  20. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    Good day All,
    One (1): Air Injection Tube with Check valve: $100 + Shipping
    One (1): Oil Radiator Line (top) : $75 + Shipping
    One (1): Oil Radiator Line (bottom): $30 + Shipping
    One (1): Front Bank Divertor Valve and mounting bracket: $50 + Shipping
    One (1): rear Bank Divertor Valve and mounting brackets: $50 + Shipping
    One (1): Used Cylinder Head (Rear Bank / Right) with matching valve cover and oil filler Cap: $500 + Shipping
    Cheers,
    Sam
  21. samsaprunoff
    4,457
    Edmonton, AB Canada
    Sam Saprunoff
    Good day All,
    One (1): Air Injection Tube with Check valve: $90 + Shipping
    One (1): Oil Radiator Line (top) : $60 + Shipping
    One (1): Oil Radiator Line (bottom): $20 + Shipping
    One (1): Front Bank Divertor Valve and mounting bracket: $40 + Shipping
    One (1): rear Bank Divertor Valve and mounting brackets: $40 + Shipping
    One (1): Used Cylinder Head (Rear Bank / Right) with matching valve cover and oil filler Cap: $400 + Shipping
    Cheers,
    Sam
  22. Jollyharbour
    Jollyharbour Rookie
    Jul 20, 2015
    14
    Surrey, UK
    Richard
    Hi Samsaprunoff,
    Do you still have this cylinder head for sale? I need to check which side i need but this is the right part number. I have also had a broken valve on my 1978 308GTB which has punctured a hole in one of the cylinder heads.
    Richard.
    +447795970240
