Ferrari 308 ignition timing | FerrariChat
Discussion in '308/328' started by Pierfrancesco natale, Dec 12, 2019.
  1. Pierfrancesco natale
    Oct 18, 2019
    7
    Italy
    Hello gents, sorry for my bad writing, i’m italian, i want to understend the timing of my Ferrari 308 single distributor, i put the engine at pm1-4, in the distributor the red sign need to stay aligned with the cylinder One or i need to rotate something???
  2. Steve Magnusson
    26,932
    #2 Steve Magnusson, Dec 12, 2019
    You need to be at PM1-4 and be at the end of the cyl # 1 compression stroke (i.e., both cyl #1 valves need to be closed). Then select the closest spline position when mounting the distributor that has the distributor rotor pointing towards the red mark. That should be good enough to start the engine -- then the distributor housing is rotated at idle to get the final desired warm idle timing.
    On a wet sump, determining both cyl #1 valves are closed at PM1-4 can be done by looking in the oil filler opening.
    On a dry sump, you'll have to guess (if you didn't make some extra external marks yourself beforehand). Just try it at the PM1-4 mark -- if it won't start, return the crankshaft to PM1-4 with the distributor rotor pointing at the red mark, then remove the distributor and rotate the crankshaft exactly 1 revolution to PM 1-4 again. Then remount the distributor aligning the dist rotor to the red mark again and see if it will start.
    Dane, derekw and waymar like this.
