Ferrari 308 problems | FerrariChat
Discussion in '308/328' started by zwoemba, Jan 23, 2007.
  1. zwoemba
    zwoemba Formula 3
    Nov 22, 2003
    1,834
    #1 zwoemba, Jan 23, 2007
    Hi all
    Somebody I know recently bought a Ferrari 308 GTB. There are a few small problems. The speedometer is currently in MPH and it has to be in KMH. Does somebody know where I can find one? I've did a search on the well known Ferrari parts websites but I couldn't find it :(
    Another problem is the gearbox. There are 3 cog wheels in the gearbox. They need to be replaced but they are very expensive. Maybe somebody in here has those cog wheels and doesn't need them? The part numbers are 105542, 105543 and 105544. Pics are attached.
    Regards,
    Jeroen
  2. BigTex
    79,379
    Houston, Texas
    Bubba
    I'm always in the market for a working US style speedo.....talk to me!
    Martin in Cavallino Motors in Miami (site sponsor) had a 308 tranny he was gonna use as a table....see if he'll pull the gears!
    Welcome, brudda!
    *308GTB club handshake*
    tomberlin likes this.
  3. BigTex
    79,379
    Houston, Texas
    Bubba
    Fuuny how the US cars wander back to Europe, and the Euro cars are running around over here!
    Second case I know of a US speedo being swapped...
  4. jwise
    jwise Formula Junior
    Apr 2, 2003
    781
    Portland Maine
    Why do the three gears need to be replaced?
  5. tvine
    tvine Formula Junior
    Jul 19, 2006
    270
    Cadillac, Michigan
    Tom Vine
    What is wrong with the gears, I have a spare middle and lower I will part with if they will help you out. I will check the part numbers, what year is your car? I also have a spare cover.
  6. BigTex
    79,379
    Houston, Texas
    Bubba
    I see a little rust, common when car's been stored..
    Get that greasy part off your Owner's Manual!
    That BOOK is a $200USD part! LOL!
  7. zwoemba
    zwoemba Formula 3
    Nov 22, 2003
    1,834
    First of all, I want to say again that this car isn't mine! A good friend of me asked me to put this message here!
    Hi, I will contact Martin. I let you know something when the speedo will be sold.
    Some 'teeth' (don't know the exact name in English) are worn out and so they don't run over smoothly into the other cog wheels. I don't know exactly the year of the car, the only thing I know is that it is an early 308 with carbs. I'll check it out... I let you know something for the spare cover :)
    EDIT: it's a 1977 308 GTB!
  8. zwoemba
    zwoemba Formula 3
    Nov 22, 2003
    1,834
    Ex Garage Queen, so there's some work on it. It will take some time but everything will be fixed :)
  9. BigTex
    79,379
    Houston, Texas
    Bubba
    I'll help...
    1977 308GTB #XXXXX
    1977 308GTB #22127
    1977 308GTB #22641
  10. BigTex
    79,379
    Houston, Texas
    Bubba
    It may be possible to send unit for new silkscreened dial.........see if anyone in Europe can handle that, if unit works fine.
    Lot's of Boxers were done this way when new, to come to USA......
  11. zwoemba
    zwoemba Formula 3
    Nov 22, 2003
    1,834
    This 308 has s/n 22397
  12. BigTex
    79,379
    Houston, Texas
    Bubba
    Welcome aboard! ;)
    They all have little problems......
  13. Trobaso27
    Trobaso27 Karting
    Nov 19, 2023
    59
    Fabio Nardozzi
    Hello to everyone who is reading this and can help me. I just picked up a 1983 Ferrari 308GTS. I was running the car and everything was working when the heater fan blew a fuse and keeps on blowing fuses. I checked out that the fans are working properly and they are both turn on and are blowing but the air is not getting to the cabin vents. What is causing the fuse to blow if the fans are running properly. Hope someone has had this problem and can help me figure it out. thank you
  14. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    Check the relays. Maybe it is bad.
  15. Steve Magnusson
    26,784
    Check that the filters, #25, in the heater boxes are not blocked and that the various hoses and valves/cables are in the proper places and working:
    https://www.ferrariparts.co.uk/diagram/ferrari/308-quattrovalvole/117-heating-system
    If there's enough "drag" in the heater motor(s) (dirty bearing, old grease, hoses blocked/kinked, etc.) to reduce their RPM = that causes a higher current draw (and they are in a tough location that ingests a lot of debris/dirt/leaves).
  16. Trobaso27
    Trobaso27 Karting
    Nov 19, 2023
    59
    Fabio Nardozzi
    So far I can't find anything the heater blowers are blowing strong and no clogs that I can find. Any other things I can try to look for to find the problems?
  17. Steve Magnusson
    26,784
    If the air isn't reaching the cabin vents (when the fans are running), you have to have a problem somewhere. The next level would be to measure the current each fan motor is actually drawing to see if that is what is causing the fuse to blow -- if there is a bad rivet connection at the fuseblock, this can cause enough I^2*R heating of the fuse to melt the fuse element even though the current isn't enough to blow the fuse by itself.
  18. JuLiTrO
    JuLiTrO Formula Junior
    Nov 2, 2017
    393
    Julio Saiz
    Replace the original fusebox with "Birdman" aftermarket.
    This is no brainer first thing to do in a 308
  19. Harry-SZ
    Harry-SZ F1 Rookie
    Is it possible to wire the fans the wrong way round?
    So that they are blowing the other way?
  20. Trobaso27
    Trobaso27 Karting
    Nov 19, 2023
    59
    Fabio Nardozzi
    the fans were blowing fine in the biginning air flow was good and after that the airflow stopped. I looked at the blowers and they are working fine blowing air bu it's not making it to the vents. I do plan on replacing the fuse panel I have ordered it already.
  21. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    628
    Massachusetts
    Joe
    You say there is no air to the vents. Are your cables working? I would check each one to see if the cable is still connected to the control lever (could be a loose screw). If so, is it actually moving the vent in and out?
    The other possibility is the hose may have come loose from the heater boxes or vents.
  22. Trobaso27
    Trobaso27 Karting
    Nov 19, 2023
    59
    Fabio Nardozzi
    I have everything still open in front where I can see all the hoses and all are connected and the cables are still attached to the screws. I have lubricated all the connections of the cables to the three-way adjustment port from top to bottom vents. It's just a freaking mystery.
  23. Trobaso27
    Trobaso27 Karting
    Nov 19, 2023
    59
    Fabio Nardozzi
    IF THE HOSE HAS COME LOOSE FROM THE HEATER BOXES THE FUSE WOULD NOT BLOW BECAUSE THE AIR WOULD BE FLOWING. I CAN SEE IF THERE IS AN UBSTRUCTION IN THE LINE THAT THE AIR IS FORCED BACK TO THE BLOWERS THEN THAT WOULD PUT STRESS UNDER THE BLOWERS AND CAUSE THEM TO GET HOT AND BLOW THE FUSE. SUCH A SIMPLE PROCESS FOR THE AIR TO FLOW BUT YET SOMETHING PROBABLY REALLY STUPID IS HAPPENING FOR THE AIR NOT TO FLOW. I THANK YOU AND EVERYONE ELSE ON HERE FOR YOUR IMPUT. PLEASE KEEP IT COMING.
  24. Trobaso27
    Trobaso27 Karting
    Nov 19, 2023
    59
    Fabio Nardozzi
    I have looked at the control levers and they are still hooked up to the cables but what I am seeing is that when I move the lever back and forth the cables themselves are not moving both the whole insulation is. The cable inside the sleeve must be somehow stuck in there against the sleeve pulling the cable by hand or moving the insulation should release it. so far everything I am looking at is working. the two heaters #25 are they there just to warm the air up so air flows through it cold or hot? Just wondering like somebody mentioned before to check out to see if airflow is going through them but they are stationary so I can't mobe them. Any thoughts?
  25. jmaienza
    Jan 8, 2009
    628
    Massachusetts
    Joe
    Regarding the lack if airflow. It's only logical that something is blocking the air. Only several possibilities: a clog in the flexible air hoses or vents, a plugged heater box filter (if the filter is still even there), a clogged heater box core or a closed or inoperative heater/defroster vent flap (BINGO)
    Obviously, you want the insulation to be held stationary by the clamps at the ends and the inner wire to move freely when the lever is moved.
    You need to buy a motorcycle lubrication tool and start to lubricate the cable at both ends. Hopefully this should free the inner cable and clean out the rust or debris. If that does not work, you can replace the cables. Bicycle brake cables which are thicker, as opposed to derailer cables which are thinner, can be used as a substitute.
