Ferrari 308 Sodium Valve Survey | FerrariChat
Discussion in '308/328' started by Octonion, Feb 10, 2022.
  1. Octonion
    Octonion Formula Junior
    Dec 30, 2020
    344
  2. Rifledriver
    37,106
    #2 Rifledriver, Feb 10, 2022
    This is going to be just like all the timing belt surveys.
    You haven't been here long have you?
    And some of these cars are 48 years old. Just how do you expect the 9th owner to provide meaningful information?
    dinogt4guy and EP328 like this.
  3. Rifledriver
    37,106
    Oh and that mileage thing. For several years the cars had an 85 MPH speedo to comply with federal law. Owners most often had them replaced with the standard speedo.
    Also the speedos broke a lot in the old days and we replaced tons of them.
    The result is a very large sampling of the cars real mileage is lost to history.
    I almost forgot. Most of the model years 80-81-82 US versions got engine rebuilds under warranty. Who knows how many miles are on most of those?
    GordonC likes this.
  4. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    Mine has one head with original sodium filled ex valves. Changed the others due to senior citizen moment where I bent all 8 valves in rear head. I've owned my 78 since 80 and put 65 k miles on it as daily driver until parked in 91. Not raced other than the occasional drag race (including some missed shifts) but lots of times to 7+K plus extended full throttle runs (10 miles or more) back in the day. I wouldn't change them unless you had it apart for some other reason or your really going to beat the crap out of it to the point of floating the valves at which point something will break.
    Barry
  5. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I'm going to use a number that isn't really correct, but might be in the ballpark: let's say 3500-4500 such cars were made. How many owners of those cars do we actually have in this forum?
    Unless you're able to get accurate data on a very large number of cars - let's say 25% (not even getting into statistical errors from comparing years vs carbs vs injection - if that's even a factor), the numbers will be of little use. At the very least - if this is just for the sake of curiosity, I'd expect you'd also want to know how many owners here do NOT have original valves.
    In other words, it would be like going to a pizza place and polling, "how many people here like pizza?" That answer wouldn't give you much insight into how many people don't ever eat it.
  6. Octonion
    Dec 30, 2020
    344
    That makes total sense. It's called sampling bias :) So I added a column to denote if they have sodium valves or not to capture both. I also understand that this is going to be a very small subset. But some data is better than no data.
    OTOH, if it really affects every single sodium valve car that Ferrari made, I wonder why there was no class action lawsuit back in the day...
    Saabguy likes this.
  7. Dr Tommy Cosgrove
    36,439
    Birmingham, AL
    Tommy
    Beat me to it. Word for word.
  8. Rifledriver
    37,106
    There may have been a lawsuit but it would of been before any of us was born. And I was born well over 60 years ago. How about you?
    So what you are really saying here is we are going to extrapolate and make up a number from seriously incomplete data.....Sounds like fun.
  9. Octonion
    Dec 30, 2020
    344
    Based on what you are saying,
    #1 every Ferrari with a sodium valve is defective from the factory and a time bomb waiting to explode.
    #2 every old Ferrari 308 should really be considered TMU
    So over 4000 308s that Ferrari made have a defect from the factory that could blow up the engine at anytime. Doesn't this imply that they do not meet the federal motor vehicle safety standards as power train failure in 100% of Ferrari's with sodium valve means none of them meet the FMVSS?
    Here's one issue on the NHTSA's website indicating a faulty fuel line that has been recalled. I found none for a sodium valve failure.
    I never said I am going to extrapolate anything nor did I make any blanket statements.
    https://www.nhtsa.gov/vehicle/1975/FERRARI/308GT#recalls
  10. Rifledriver
    37,106
    #10 Rifledriver, Feb 11, 2022
    Site a single one of my statements that would lead any reasonably intelligent person to conclude a single one of your assertions. Just like everything else you are ignoring what is said and redefining it to your needs.
    You should study up on the parameters for a recall.
    ProvaMo likes this.
  11. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    my 78 euro gts dropped a sodium valve in 1992 with 45000Km. that was with the previous owner, who has rebuilt the motor and used non sodium valves.
  12. Rifledriver
    37,106
    So as a European version does it have air injection? And if so when was it installed?
  13. Rifledriver
    37,106
    And by the way, 308 GT4, 308 GTB and GTS combined plus 308 GTBi and GTSi combined totals over 11000 units, not 4000.
    I guess we are not counting all the 250, 275, 330, 365, 335, 375, 410, 512 etc motors. Those don't count I guess.
    GordonC and ProvaMo like this.
  14. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    at the time, it did not have air injection. it did for a little while after the rebuild to pass emissions (barely), but i have since installed 4 TWM throttle bodies and the Holley HP EFI ECU. now it passes emissions with flying colors on a consistent basis. even without cats and air injection, but i do need the cats for a visual, so i have a set i can bolt in and out in place of the mufflers for emissions time (did i just say that out loud? - lol)
  15. Rifledriver
    37,106
    Thank you for that. I guess now we can put the wives tale of valves only breaking in US cars with air injection to bed where it belongs.
    100% of our respondents show it to be untrue.
    cavallo_nero and GordonC like this.
  16. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    Some data > no data
    I entered what I know about my 2V cars.
    cavallo_nero and Octonion like this.
  17. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    Pictures, or it never happened!
  18. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    pics of what? the valve, air injetion, mufflers, cats, emissions report or twm install?
  19. Ferraridoc
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    The throttle bodies, of course!
  20. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    myronx19 and Ferraridoc like this.
  21. myronx19
    myronx19 Formula Junior
    May 27, 2012
    653
    Toronto, ON Canada
    Myron Samila
    That would be out of scope for FMVSS.
    You could argue that you'll have loss of propulsion, but you can coast to a safe stop after you drop a valve (or run out of fuel for that matter) - mitigating a crash.
  22. Octonion
    Dec 30, 2020
    344
    I have not read the regulation in it's entirety to agree or disagree. But a good lawyer worth his/her salt can probably write up a good case especially if the failure rate is 100%.
  23. Rifledriver
    37,106
    You keep saying 100%. No one has claimed that. No one has claimed anything close to that. And no, there are clearly defined issues covered by recalls and that is not it.
  24. Octonion
    Dec 30, 2020
    344
    That's just how I would characterize the fact that every sodium valve is suspect unless replaced. Unfortunately, there isn't enough data to draw a bathtub curve to fit the failure rate.
  25. Rifledriver
    37,106
    I assume it is based on your very long period of experience in the Ferrari repair world?
