Ferrari 308 with wide body kit, engine options | Page 2 | FerrariChat
Discussion in '308/328' started by doggydoggen, Jan 7, 2024.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,633
    The twilight zone
    The Butcher
    That is the argument for focusing on a wide powerband over a high peak hp. With the blower engine of the V12 there are usually 3 or 4 gears to pick from that will work...it certainly doesn't optimize getting the power to the ground but that a good excuse to just make sure there is extra power available is needed/wanted
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,633
    The twilight zone
    The Butcher
    you will not (easily) be mounting a 345 or 355 or 360 to a 308 trans.
    The idea with a 348 or 355 would be buy the eng/trans and make it fit the 308 chassis.
    doggydoggen likes this.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,633
    The twilight zone
    The Butcher
    285 fits in the stock fenders (its what I run), with a wide body kit I'd think 315 is the go.
    smg2 likes this.
  4. doggydoggen
    doggydoggen Karting
    Apr 25, 2023
    120
    Sweden Umea
    Doger Karlstrom
  5. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,171
    Dumpster Fire #31
    SMG
    As Mark pointed out, there's no easy way and I would not recommend trying to mate the 348/355/360 engine to the 308 gearbox. 308/328 engine to 360 gearbox is doable but not easy.
    No the 348 'lump' is not a bolt in thing. Chassis will be to be modified for the mounts and stretched I think 4-6" for the axels to line up.
  6. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,171
    Dumpster Fire #31
    SMG
    Kinda... The 4L NA has gobs of low rpm tq and of course high rpm. The gear ratios are just too short initially and while 5th is ok for cruise at say 45-50 for that low rpm since it's got the umph at highway speeds it's too short still. It needs a taller 1st and at least a 6th.
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,633
    The twilight zone
    The Butcher
    help me, is that 3150 cc/rev? I lent out my engine simulator key so I can't ruin it for you but I used a lysholm 2300 which is 2300cc/rev and it made 24psi on my QV which was 500hp/420ftlbs. If that thing is 3150cc/rev, well it could make more.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,633
    The twilight zone
    The Butcher
    well when are you guys going to start offering custom drop gears?
    Yes, I don't use 1st very often on this or the last blower engine. My 1st is 24% higher than normal 1st but 2nd (also 24% higher) is still the right choice other then rolling through parking lots which would be a problem without 1st, 1st is about 10mph at idle, 2nd 14 or 15 so I end up clutching a lot whiteout using 1st. That is just life when you have buckets of torque I guess.
  9. doggydoggen
    doggydoggen Karting
    Apr 25, 2023
    120
    Sweden Umea
    Doger Karlstrom
    Yes it is 3150cc/rev, for what i can understand it is one of the finest blower you can buy?, the guy ho sold it to me is a friend of mine, this guy is incredible, he build engines, he cad the pistons and rods him self, then a friend of him make the parts after the specifikation, he build a v6 engine this winter for a racecar he is building, all the interial parts is custom made, like pistons rods, etc, he also make own camshafts, also the paddelshift is air plumatic, did all this parts custom also, hissing and blowing, petisss, pethiss, when you drive the car, lol, and works very well.:)
  10. doggydoggen
    doggydoggen Karting
    Apr 25, 2023
    120
    Sweden Umea
    Doger Karlstrom
    I did read about the dropgears, something about 29/29/29, but then only 1 tooth in grip so 28/29 would be ideal, do they sell this parts somewhere or do you need to fabricate them yourself.
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,633
    The twilight zone
    The Butcher
    what kind of idiot makes there own cams? :D
    That is a fine blower and should get you around 30ish psi if that is what you want. Obviously you can spin it slower and make less boost but that will give you a bit less boost at low rpm than you would have with a smaller more optimally sized blower for the boost/hp your after. Now maybe limiting the low rpm boost is a good thing as it will encourage you to use more rpm. With the 2300cc blower geared to match the 7700 308 redline (so it was at 12k iirc) I saw about 24psi peak and about 12psi at idle, about 18psi 300-5500 then it would climb again as the engine torque and flow per rev wanted to drop but the blower was like, oh no, I insist :) you can just scale what I had to the bigger blower and it should be close. My point was though I found in normal driving there was so much low end torque I usually shifted around 2500-3000 rpm and in first gear no matter how gently I was with the throttle at 10psi the wheels would spin, I had to be pretty carefully in 1st gear. A bigger blower spinning slower will leak more and make less boost at low rpm so maybe a good thing?
  12. doggydoggen
    doggydoggen Karting
    Apr 25, 2023
    120
    Sweden Umea
    Doger Karlstrom
    Many questions now, but did you have 24psi on standard engine or did you beef it upp, rods, piston?, im not familar with the 2.9l engine, but 500hp on standard engine, is that safe?
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,633
    The twilight zone
    The Butcher
    There was a place that had a race kit, straight cut gears (so loud) that gave you a handful of optional ratios. stock is 27/30 (the middle idle does not affect the ratio) and I worked very hard to swap then and run 30/27. The kit is bolt on and makes the idler part of the ratio because its 2 gears. I think it was like $10k for the set, not sure it its still available.
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,633
    The twilight zone
    The Butcher
    I changed the valve spring, the valve will start to float at about 18psi with stock springs. I was also running gapless piston rings just because I thought they were good, not really anything to do with boost. the rest of the engine was stock other than the EFI replacing the CIS. Some have expressed concerns with the stock rods, carrillo makes a nice replacement set but I had stock rods and pistons.
    Edit, oh and a better clutch of course
  15. doggydoggen
    doggydoggen Karting
    Apr 25, 2023
    120
    Sweden Umea
    Doger Karlstrom
    This sounds wonderfull, blower it is, now i only need to fabricate the parts needed, did you find the crankpully or did you make a custom?, i will probably ask you questions in the future.:)
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,633
    The twilight zone
    The Butcher
    I made it and pinned it (iirc) to the OEM damper. it was about 20 years ago but I'm remembering cut a slight groove in the front of the damper pulley that the new blower pulley fit into to support its, like 3 driver pins into the hub of the OWM pulley and a longer bolt to hold it all on. I think it was a 10 rib belt? or 12. don't recall but the blower company (whipple) hade off the shelf blower pulleys so I made the drive to match those. The final setup was like 6.9" bottom and 3.5" top?...the blower was at 12k when the engine was at 7700. the 3.5 on top would try to slip and also walk off due to flex in the drive snout which I fixed with a support and the tensioner on the outside forcing the belt to at least 270 degrees of wrap on that 3/5" pulley. I had an air/water intercooler stuffed into the itake and the whole thin fit under the stock deck lid, with about 3mm clearance :eek:.
    A 2v would need a pretty different setup. I built a manifold for 1 once, the blower had to be on top in a much more conventional looking design, or mounted over the rear cam cover maybe, I never tried that.
  17. doggydoggen
    doggydoggen Karting
    Apr 25, 2023
    120
    Sweden Umea
    Doger Karlstrom
    #42 doggydoggen, Jan 7, 2024
    I wonder if this should be a option?, use a edelbrock victor junior, it says it is for ferrari 308, but maby a error, dont know?
    some welding and fabricating, weld in injection, rail then the blower mounted directly to manifold and mount a sutible throttlebody on the back of blower?
    https://sportcompactwarehouse.com/edelbrock-2981-victor-jr-351-w-intake-manifold-non-egr-3500-7500rpm-ford-351w-for-4bbl-carbs-9-5-in-deck-height-racing-use?Year=1978&Make=Ferrari&Model=308+GTS
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,633
    The twilight zone
    The Butcher
    I don't think I have any pictures kicking around. But that's about what I made out of billet for the 2v I worked on. I'm not sure you could make an off. The shelf manifold work or probably would be more trouble than it's worth. A Ford mustang TB, I forget the year, it's a double bore oval thing fits the blower opening pretty well or you can use a more modern TB with throttle by wire.
    The QV intakes I've done were all weldments, seemed easier.
  19. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    196
    Boerne, TX
    Rodney Bolt
    Man, your builds are absolutely stunning. One of these days, hopefully soon, I'll be sending my car ('89 328) for you to work your magic. My dream is a NFF bullet proof, 100k mile, 350-400 WHP NA setup that I can drive the stink out of (pun intended).
  20. doggydoggen
    doggydoggen Karting
    Apr 25, 2023
    120
    Sweden Umea
    Doger Karlstrom
    Today i talked to my friend ho make his own camshaft and engine part, he is gonna help me cnc machine all the parts needed, he also gonna make it wather cooled with stand alone system with cooler and waterpump that turn on in 3500rpm, he is exited like me, this will be fun.:)
  21. doggydoggen
    doggydoggen Karting
    Apr 25, 2023
    120
    Sweden Umea
    Doger Karlstrom
    He also told me that to use standard piston rings, but need to take the engine apart and regap the rings, i would be wise to listen to him, he is now building a compreesor mated 1250hp hellcat engine, he nows his stuff.:)
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,633
    The twilight zone
    The Butcher
    Yes, that sounds right. When I did mine I was doing a rebuild and did change the gap, I'd forgotten all about that.
    For the cooler I had the water/air in the intake and a pair of go-kart radiators in the front wheel wells. The pump turned on with rpm but also with boost and inlet air temp....again, it was 12psi at idle rpm so lots of opportunities to make heat.
    Last, the oen head gaskets do not tolerate detonation. The flame ring cracks and bits can go flying...don't let it detonate or use different gaskets.
  23. doggydoggen
    doggydoggen Karting
    Apr 25, 2023
    120
    Sweden Umea
    Doger Karlstrom
    Again many thanx for the input, your nowledge about this is super good info.:)
    He is not fimilar with this perticular ferrari engine, but from diplacement he talked about 0.8 ring gap, do you remeber what gap you used?
  24. HotShoe
    HotShoe F1 Veteran
    8,632
    Lake Worth, FL
    Anthony Lauro
    Forgive my ignorance but wouldn't it be easier and more economical (relatively speaking) to by a complete 355 engine, cradle, rear assembly/transmission/suspension and just fab it onto the 308 chassis?
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,633
    The twilight zone
    The Butcher
