Ferrari 348 Flywheel/Damper | FerrariChat
Discussion in 'Technical Q&A' started by Ferrari_348, Jun 12, 2009.
  1. Ferrari_348
    Ferrari_348 Rookie
    Jul 7, 2006
    5
    Montreal, Canada
    Dino
    I was having problems with hot starts and hearing some knocking noise coming from down below so time to investigate.
    To make a long story short it came down to the Flywheel/Damper, when I had it in my hands I could hear loose pieces inside when shaking it, so I opened it to discover that most of the plastic pieces that hold the little springs on the damper where pretty much shred to pieces and floating around in the assembly.
    My question: Does anyone know if there are any kits available to replace the parts in the flywheel/damper?
  2. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    Call Daniel at Ricambi
    http://www.ricambiamerica.com/
    --Mike
  3. fatbillybob
    Aug 10, 2002
    29,026
    socal
    Not available but contact plugzit on fchat. He has alot of my old 348 parts which include some old flywheel guts. If you can't find the internals you will have to buy a new unit for big bucks. I have had race proven success with deleting the FW internals and welding the unit up which got rid of just under 10 lbs of rotating mass which mildly improved out of the corner acceleration. Do a search I have posted on that before.
  4. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    The 348 Parts Manual only shows the flywheel as an assembly, does NOT show the internal parts at all, but it also does not show the Kluber grease although it's obviously available from them. The Workshop Manual has nothing to say about rebuilding or even regreasing the flywheel, although they do show a quantity (incorrect) for the grease.
    Somewhere (at Voith??) there are probably boxes full of the internal components, but I've never heard of anyone being able to acquire them.
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It would be interesting to meet the person responsible for this odd mechanical marvel and pick his brain regarding it's reason for being.
    It seems an anomaly in the automotive world (I'm not familiar with other examples of this type of flywheel in use).
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Send a pm to randyleepublic, he was working on a solution and may be able to machine you up some new plastic guides.
  7. windsock
    windsock Formula 3
    1,153
    Is this a single disk or dual disk clutch in your 348. there are virtually no parts left for the single disk units and will likely need to upgrade to the dual disk unit which will require the remaining clutch pieces as well.
    Generally the plastic pieces become destroyed as the springs wear and the unit begins to shake much more than designed and smashing against the stops. We see one or two a year and upgrade to the dual disk units. Even if the single disk flywheel is in good shape the dual disks are worth the upgrade.
    Good luck.
  8. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    +1... Unless you can find reasonably-priced spare parts, I would think you could find a shop to reproduce them. Of course, you have to have good samples to reproduce, if all of yours are destroyed. Let us know what you find, and welcome to Ferrari Chat!
  9. Ferrari_348
    Ferrari_348 Rookie
    Jul 7, 2006
    5
    Montreal, Canada
    Dino
    It's a dual disk clutch.
    I'm still looking around, I sent a few pm's to some fchat guys as suggested and see what comes out of that. A big thank you to all for your help, greatly appreciated. I'll keep you posted on the end result.
  10. Rifledriver
    37,106
    Interestingly enough in this case it seems Ferrari copied the Germans. They have been using those stupid things going a long way back. Most recently on BMW I believe. Ferrari would be far better off if they just forgot Germany existed. It is the source of most of the more serious problems they have.
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    For anyone with a 348 hot start problem, do the patented, world famous No Doubt hot start test before removing your flywheel (because hot start problems aren't always due to a bad flywheel or grease issue).
    Start your 348 cold, drive until hot. Now pull over and turn off the motor. Within 10 seconds after the engine stops, attempt to restart.
    If your 348 restarts easily on the first try at this point, then you DO NOT have a flywheel/grease hot start problem (more likely culprit is a bad fuel pressure regulator or two).
    To confirm a fuel pressure issue, turn off the motor and wait for 2 minutes. If your 348 is now difficult to restart, then check your fuel pressure regulators.
    This is a free test. It requires no wrenching.
    < /end No Doubt hot start test >
  12. chevro
    chevro Rookie
    Nov 29, 2011
    7
    Quebec,Canada
    serge
    Hello!, i have the same problem looking for the internal plastic guides ,did you find some?
    Tank you!!!!
    Serge
  13. chas-3
    chas-3 Formula 3
    1,281
    Colorado
    Chuck
    I've been waiting for someone to reproduce those internal pieces. But as stated above, you have to have like-new pieces to copy from. The wait continues . . .
