ferrari 355 diagnostic system | FerrariChat
Discussion in 'Technical Q&A' started by ndg.performance, Mar 13, 2012.
  1. ndg.performance
    Mar 12, 2012
    25
    Abdullah
    Can any one tell me if there is any diagnostic system I can find in the market other than visit FERRARI dealer?
  2. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,765
    US of A
    Michael
  3. ndg.performance
    Mar 12, 2012
    25
    Abdullah
    Thanks michael but this diagnostic is for garage use not personal, I need more simple and more friendly use can just let me know the errors and cleare them.
  4. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    If it's a 95, you can pull the diagnostic codes yourself (OBDI). If it is a 96+ I believe any good OBDII reader from your local auto parts store will give you the basic diagnostics, clear codes, etc, but not the extended ones (F1 transmission for example).
    IIRC some of the 96 OBDII ports had a couple of wires out of sequence from the factory - obviously if your car falls in that group that would need to be fixed first.
  5. ndg.performance
    Mar 12, 2012
    25
    Abdullah
    Thank you for the info my car is 1998 Any idea where can I find nurmal OBDll?
    Cause all our OBD's in the country is specialized on particular car.*
  6. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,765
    US of A
    Michael
    As far as just a nice at-home scanner I like the Cen-Tech Model 99722. You can get it on-line under $100 USD.
    It will read your OBD2 codes but I would bet that it will NOT read ABS faults or Suspension faults on a 355.
  7. ndg.performance
    Mar 12, 2012
    25
    Abdullah
    Thanks michael I will check that and I hop it can do the needful.
  8. f355spider
    f355spider F1 World Champ
    18,055
    Please fill out your profile, it will go a long way in assisting us, so we don't have to ask each time what year car you have, or your location.
    A 1998 355 should accept a standard OBDII code reader. I have listed the code lists a few times in the 355 section. (actually the 360, but most all of the codes are the same, no one has found or posted the 355 list yet) North American cars have a problem with the OBDII connector not being properly grounded, and there is an open recall to have it fixed by the FNA dealer at no charge. I am uncertain if the same problem exists for other market 355s. Worth checking, because if the ground is not present, you may not be able to scan properly with some scan tools.
