355 - Ferrari 355 Spider Top Roof Mechanism ALL Common Issues & FIXES | Page 3 | FerrariChat
355 Ferrari 355 Spider Top Roof Mechanism ALL Common Issues & FIXES
Discussion in '348/355' started by spiderscott, Jan 27, 2019.
  1. WATSON
    24,076
    WI
    Qavion likes this.
  2. WATSON
    24,076
    WI
    H-2 has two wires coming from it.
    One is black the other Purple / Black
    Qavion likes this.
  3. WATSON
    24,076
    WI
    I do not get a BRAKE light on start up.
    Where does the wire go from Pin 7?
  4. Qavion
    Qavion F1 World Champ
    14,652
    Ian Riddell
    On gated cars at least, pin 7 goes to the brake fluid level and brake pad wear sensors (and illuminates the brake warning light). There is also a module which illuminates the light on startup. P/N 61830700 on USA cars. All these wires for these sensors, etc, are spliced together. On gated cars, there is a separate PARK light on the dash (which sits where the Slippery Road Mode light is on the F1).
    I don't understand why your pin 7 is missing. If you have your binnacle sitting on your work bench, try to see which pins your BRAKE warning light is attached to. i.e. the 2nd light on the bottom row. It should be attached to the Green/white wire (your pin 6) and one other pin/wire.
    Thank you, but I think you've taken a photo of plug "I"
    Plug H is the blue one.
    It's a pity you didn't take that photo at a different angle, I can almost see H-2. I was looking for a white/red wire to confirm that the wire went to the fog light annunciator on the dash. On some other cars it is orange.
    Actually, those wires on I-2 are horn-related. The purple/black wire comes from the horn buttons. The black/yellow(?) wire comes from the Immobiliser ECU. In some markets, the immobiliser triggers both the siren and the horn.
  5. WATSON
    24,076
    WI
    Facepalm. Sorry about that. I'll take it back apart and get the right wire later.
    Qavion likes this.
  6. WATSON
    24,076
    WI
    I have the 61830700 module on my car (1998 F1). What wire should go from what pin on the module to Pin 7?
  7. Qavion
    14,652
    Ian Riddell
    #57 Qavion, Sep 23, 2023
    Should be the pink wire on pin 8 (the pin by itself).
    Ferrari have done their best to save money on the switchover from 2.7 to 5.2 and to F1. The instrument panel internal wiring seems to be the same (with regards to the warning lights). All that has been changed are the annunciator light bezels. If you had a wire or pin on pin 7, it should be attached to the BRAKE light.
  8. Qavion
    14,652
    Ian Riddell
    Have you looked further back up the harness to see if there are any pink wires hanging in the breeze with, perhaps, a broken pin on it?
  9. WATSON
    24,076
    WI
    I kind guessed that as I was testing the pins and lights today.....
    My car had a previous owner that did some odd ball stuff so who knows what he did with the wiring (he had it all apart and pretty messed up).
    So if I ran a wire from pin 8 of the 61830700 module to Pin #7 on the 13 wire connector, would that get me a BRAKE light with the hand brake engaged?
  10. WATSON
    24,076
    WI
    I'll go look. Solid pink?
  11. Qavion
    14,652
    Ian Riddell
    Affirmative.
  12. WATSON
    24,076
    WI
    OK. Stand by...while you eat breakfast, I have to go out to dinner with the Mrs.
    Qavion likes this.
  13. Qavion
    14,652
    Ian Riddell
    No, but you should get the brake warning light on startup and brake warning lights when your brakes are broken. To get a parking brake light, you need to splice one of those orange/black wires into the pink wire/s.
  14. Qavion
    14,652
    Ian Riddell
    Thanks for the reminder :D I do get rather involved sometimes with these things and forget to eat.
    Something to consider. If you fix the BRAKE warning system, you may find you have faults on the brakes you didn't know you had before :p
    Also, if you splice the park brake wiring into the brake warning wiring, if your brake warning lights come on due to brake wear or low fluid, you will be able to operate the roof at any vehicle speed. I think the probability of you doing that is pretty low ;) and can always stop this happening by putting a diode in the circuit.
    I can't believe the F1 car doesn't have a Park brake warning system. You may find that the wires are spliced somewhere already.
  15. Qavion
    14,652
    Ian Riddell
    Don't worry about pulling your frunk relay panel to pieces again. I managed to find an OEM USA diagram which had colours which matched your car (for the foglight wiring). In the diagrams I found, the white/red wire does go to a different pin on the LH instrument panel plug, but that makes perfect sense because of the relocation of the light on F1 cars.
  16. Qavion
    14,652
    Ian Riddell
    I don't know if you want to modify your pin numbering chart in post 51 for the F1 connector...
    The WSM F1 Gearbox section has this diagram ...
    Which makes the pin numbering like this:
    You have white/black on pin 1, not pin 7, etc, with the unused pins pins on 3, 4 & 5 (instead of 10, 11 & 12).
    (Just in case you get confused later).
    The instrument binnacle pin numbers 13, 2 & 11 shown in the WSM F1 graphic above also match with the pin numbers on the OEM Lighting Wiring Diagram's instrument panel left hand plug ("D") reading left to right.
    Anyway, we are probably a little off track from getting your brake light to work ...
    WATSON likes this.
  17. Qavion
    14,652
    Ian Riddell
    I don't know if there is a lamp installed in your BRAKE light, but you might want to try putting a small voltage on binnacle pins 7 & 6 to see if the brake light lights up. This is assuming there is a pin installed in position 7. Pin 6 is pin 8 in your table (green/white wire).
  18. WATSON
    24,076
    WI
    The reason I pulled the dash pod was to check for the bulb. It's there and works.
    Let's use your pin out numbers going forward. I just made that table so you had the correct colors.
    So power to pin 6 & 8 on the 13 pin connector socket?
    I do not see a pink wire on my harness. just a pink / black one
  19. WATSON
    24,076
    WI
    #69 WATSON, Sep 24, 2023
    I do not have this wiring diagram...is this a new one?
  20. Qavion
    14,652
    Ian Riddell
    6 & 7
    6 should be green/white on the harness side. 7 has no wire on your car.
    WATSON likes this.
  21. Qavion
    14,652
    Ian Riddell
    That's a new one I'm drawing (with your info).
    Here's a link:
    https://www.dropbox.com/t/h4IX50gcG4yBKwib
    Unfortunately, I'm running out of room on these diagrams for these additional F1 wires.
    WATSON likes this.
  22. WATSON
    24,076
    WI
    Yea, I caught that. ...and yes 6+7 gets the brake light to come one.
  23. WATSON
    24,076
    WI
    Excellent. thank you.
    Now all I need to know is where the wire comes from to go into the #7 connector.
    I have no idea why I do not have anything there. I looked down stream and do not see a pink wire anywhere.
  24. Qavion
    14,652
    Ian Riddell
    Weird. Surely it can't be standard on the F1 car. That would be dangerous not to have a brake warning light.
    Here's an updated simplified F1 diagram:
    https://www.dropbox.com/t/EUdsTenkAW6c0odf
  25. WATSON
    24,076
    WI
    Where does pin #7 on the 13 pin connector got to on a non-F1 - 5.2 car?
