355 - Ferrari 355 Spider Top Roof Mechanism ALL Common Issues & FIXES | Page 5 | FerrariChat
355 Ferrari 355 Spider Top Roof Mechanism ALL Common Issues & FIXES
Discussion in '348/355' started by spiderscott, Jan 27, 2019.
  1. Qavion
    Qavion F1 World Champ
    14,533
    Ian Riddell
    Regarding the blinker... I see the blue/black wire going to the same pin as my diagrams... pin 8. Blue/black for LH turn is universal on Ferraris of this era.
    All that is required is an earth to illuminate the turn light. You only seem to have one wire which looks like an earth (pin 9).
    The high beam wiring looks ok, too. Green/black on pin 10. All that is required is an earth. Again, pin 9. All the other pins are accounted for.
    Regarding the F1 lights, the WSM diagram doesn't specifically say which pin is which function. So the 2, 11 & 13 pins could have any assignment.
    According to the WSM diagram, the power for the lamps is supplied by the car (not the F1 module) i.e. the "+15":
    Which wire/s on plug D supply the power is not known. Possibly pin 6 (green wire).
  2. WATSON
    23,929
    WI
    Next time I am in there we will re-connect and get to the bottom if it all!
    Thanks for all your help. Priceless.
    Qavion likes this.
  3. diegougarte
    diegougarte Rookie
    Oct 21, 2023
    5
    Hi!
    im having trobubles with the roof of my spider, the hatch tends to turn at speeds (100kmh) and if youre no paying atention to hold it the roof just opens. Its so annoying because you just can not drive the fast hahah.
    How can i fix it? Is there any regulation? I think the hatch must be get locked and super tight and never move by itsleft i think…
    thanks
  4. Qavion
    14,533
    Ian Riddell
    So you're saying that the handle moves away from the stowed position?
    There is a big spring in the latch mechanism, but I don't know if the latch relies solely on this. Unfortunately, if I remember correctly, the fabric has to be removed to access the latch mechanism
    Are the hooks engaging?
    Maybe try lubricating what is visible?
  5. diegougarte
    diegougarte Rookie
    Oct 21, 2023
    5
    Thats exactly what is happening, it doest stay locked
  6. diegougarte
    diegougarte Rookie
    Oct 21, 2023
    5
    there is some diagram or manual to do a service to the latch?
  7. WATSON
    23,929
    WI
    The picture below is taken with the cloth top removed and the metal cover off.
    You might try and raise the top half way until it points straight up and see if you can access the metal cover to remove it and get at the spring.
    I'd try it now, but my car is up on the storage lift......
  8. diegougarte
    diegougarte Rookie
    Oct 21, 2023
    5
    Thanks, ill try to get into that spring… its hard to take the fabric away from that?
  9. Qavion
    14,533
    Ian Riddell
    It depends on how old the fabric and glue is. Mine wasn't too difficult, but it's possible the fabric might warp or tear.
    But I don't know for sure if the spring would cause this. Is there any any spring action in the unlock handle? I haven't heard of springs breaking. I don't think the spring is under much stress.
    I've just noticed some wires under the balls at the end of the rods which go to the hooks. I'm wondering if these help the mechanism to latch in position. Anyway, I guess a general lubrication of the mechanism won't hurt.
    Does the roof sit properly in the holes in the top of the windshield?
    Note that even if you find broken parts, Ferrari doesn't sell components for this part of the roof mechanism.
  10. diegougarte
    diegougarte Rookie
    Oct 21, 2023
    5
    Yes, the roof sits perfectly and stays locked, but for some reason with the wind the latch slowly starts to unlock and the roof sudenly opens…
