Ferrari 360 AC Compressor Bolts and connector. | FerrariChat
Discussion in '360/430' started by KimNorway, Mar 6, 2023.
  1. KimNorway
    KimNorway Rookie
    Feb 23, 2021
    2
    Kim Are Lerang
    Hello,
    I have read on this forum that several have used the AC compressor off a Vectra B. I am planning this install and have a couple of questions:
    1. The 3 back bolt holes need to be tapped, for the bracket containing the Screws: #16044024. What threads are these? I cant seem to find that information anywhere.(want to fix before I pull out the old one)
    2. The plug on my new compressor is 2-wire, but the best is probably to change the connector and just ground the - coming from the AC-compressor to the compressor like the original one?
    3.I plan to run the stock clutch wheel as I have understood there are no problems running a 3-groove belt on a 4-groove wheel.
    Thank you :)
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    Any bolt will do, just measure the diameter of the drilled hole and then look up the tapping drill diameters to suit various standard bolts.
  3. KimNorway
    KimNorway Rookie
    Feb 23, 2021
    2
    Kim Are Lerang
    Yes, It was more if anyone knew the threads on them, so I could pre-tap them. All I know is that it is M8x40
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,413
    San Carlos, CA
    Mitchell Le
    M8 1.25 pitch.
    KimNorway likes this.
