Ferrari 360 Crankshaft Bearing Failure | Page 2 | FerrariChat
Discussion in '360/430' started by silver360gt, Jan 15, 2025.
  1. vrsurgeon
    vrsurgeon F1 World Champ
    16,456
    Charleston, SC
    Curt
    IMHO get a used engine and throw it in. Enjoy it.
    I used to be in the honeymoon.. I need the original engine, original tires, original blah blah phase.. but when the novelty wears off the car is there for a relationship between the two of you, just you and the car, and that's what's important.
    jtn0514, imahorse, JPCIII and 2 others like this.
  2. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,586
    You might talk to one of the salvage yards and see what the car is worth as is. I would estimate about 100 hours to do a R&R on the engine having just done it on mine plus the cost of the used engine.
    otherwise, pull and engine out of a wreck and fix it. Very odd failure.
    silver360gt likes this.
  3. silver360gt
    silver360gt Rookie
    Oct 23, 2024
    32
    *Update on Decision*
    I decided to take the engine to Norwoods in Dallas, they will evaluate what needs to be done. If they can rebuild it for a few thousand more then a used I will go that route, if it's crazy expensive I will do a swap and make the rebuild a side project for years to come.
    one4torque likes this.
  4. silver360gt
    silver360gt Rookie
    Oct 23, 2024
    32
    *Update on Car*
    I am finally to the engine pull stage. The service manual has been great up to the point talking about electrical connections, then it's just like "remove cable" when it needs to say, "unplug connector (1), unbolt cable (2), disconnect wire (3), then remove the half rubber seal around cable to allowing the cable and connector to pass through".
    I also, found that my oil pressure sensor was missing a wire...the grounding wire to the block is there, but nothing to get a reading is attached...I would think this would cause some problems, but I always had an oil pressure reading...super strange and scary!
    Anyways, we finished getting everything loose, but did not get the angle of pull correct in the final hour, so we set it down and trying again tonight.
    mfennell70 and JaguarXJ6 like this.
  5. one4torque
    one4torque F1 Veteran
    5,598
    Houston
    One4torque
    Enjoy the journey… from my experience this car will mean more to you after you accomplish the transplant.
    jtn0514 and silver360gt like this.
  6. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,585
    San Jose
    dc
    You find the signal wire of the oil pressure sensor? If you were getting a real value then perhaps the wiring got knocked off during your disassembly? Hopefully not hooked up somewhere else.
    I recently replaced the oil pressure sender on my 996TT since it would intermittently drop to zero. Turns out when I got to it (lower engine+take a ton of stuff out) it was just a loose connection. Still swapped it for new and tightened the spade connector some. Also put in 997TT throttle body, new check valve and other "while in there" parts.
  7. collegeboy
    collegeboy Formula 3
    1,338
    Texas and Kaua’i
    Mikey
    I'm not a purist, but I would personally use the original engine, take the engine to a to shop (Not a Ferrari dealership) and have them see what they can do, get a quote, and have them rebuild it. They might be able to make it better than new even. And cost more than the car? LOL. No. that's dealership talk and prices for you.
  8. collegeboy
    1,338
    Texas and Kaua’i
    Mikey
    It's not. That's normal. Only 1 plug to it.
    grtoz, Sj_engr, JPCIII and 1 other person like this.
  9. silver360gt
    silver360gt Rookie
    Oct 23, 2024
    32
    I think so!! I haven't been this
    My thought is a rebuilt engine will be better then a used engine off eBay, but at what cost!?!
    I got everything pulled last night and dropped off the long block to get an estimate from an Indy shop. I should know something by next week. But until then I will keep posting pictures of the little things I can fix easily with the engine out!
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    I.T. Guy, mfennell70, Kerwind and 4 others like this.
  10. one4torque
    5,598
    Houston
    One4torque
    Well you don’t mess around!
    silver360gt and JaguarXJ6 like this.
  11. GogglesPisano
    GogglesPisano F1 Rookie
    3,034
    East Bay, California
    Joe
    Looks so small out of the car. At least you can clean in all the engine bay nooks and crannies now!
    jtn0514, Mel Spillman and silver360gt like this.
  12. one4torque
    5,598
    Houston
    One4torque
    If I’m
    Looking at it right.. it looks like you have the upgraded variators by virtue of the green dot.
  13. JaguarXJ6
    JaguarXJ6 F1 Veteran
    Feb 12, 2003
    5,533
    Black Hawk, CO
    Sunny
    The man is on a mission. It's going to be ready for spring at this rate!
    Making progress like he's got a YouTube channel. LOVE IT!
  14. one4torque
    5,598
    Houston
    One4torque
    And he’s not taking the retail mechanic parts changer ride… at $200-$300/hr.
  15. RedNeck
    RedNeck F1 World Champ
    12,035
    The CSA
    Me
    Don't trust the green dot. Trust the date code.
  16. Lola360
    Lola360 Karting
    Oct 26, 2023
    126
    Bay Area, CA
    Connor
    Nice job! You'll learn so much about the car in the process. Now you can take your time making everything just right to your liking. Good luck with the rebuild quote
  17. collegeboy
    1,338
    Texas and Kaua’i
    Mikey
    Good job man. Keep us updated on the rebuild cost estimate. I’m curious as well.
  18. silver360gt
    silver360gt Rookie
    Oct 23, 2024
    32
  19. RedNeck
    12,035
    The CSA
    Me
    one4torque, JaguarXJ6 and silver360gt like this.
  20. JPCIII
    JPCIII Karting
    Oct 4, 2024
    109
    Katy, Texas
    Jason P Curtiss III
  21. silver360gt
    silver360gt Rookie
    Oct 23, 2024
    32
    Nope, good ole aluminum shavings from God knows where.
  22. 360Grigio
    360Grigio Karting
    Nov 1, 2010
    150
    Steve
    I took my 360 into an independent several years and they noted the engine was running warmer than it should on a cool, fall day. They informed me of the issue and asked to inspect the cooling system and the left and right radiators. Upon inspection, both radiators had swarf partially blocking the passages. They said it was not uncommon to see swarf leftover from manufacturing in the cooling system. After replacing both radiators, the car has run great and definitely cooler in the summer months.
    one4torque and JaguarXJ6 like this.
  23. 67bmer
    67bmer F1 Rookie
    2,747
    MD
    prober34 likes this.
  24. JPCIII
    JPCIII Karting
    Oct 4, 2024
    109
    Katy, Texas
    Jason P Curtiss III
    Swarf in the lubrication system after the engine has been manufactured is inexcusable.
    Jason
    collegeboy and one4torque like this.
