Ferrari 360 f1 starting problem | FerrariChat
Discussion in '360/430' started by Majin_JT, Jul 9, 2014.
  1. Majin_JT
    Majin_JT Formula Junior
    Mar 15, 2008
    395
    JT
    hello everyone I need some help .
    Just lately my 2000 360 has been having trouble starting .
    I will turn the key and nothing it makes a slight gearbox bong noise , no fault lights at all , I have to put car into gear then rock the car several times then it will let me start the car .
    How can I cure this fault any help would be great , I have also just lately had new 1st and 2nd gear synchro changed with new selector forks and sd2 pis reset etc
    thanks
    john
  2. Majin_JT
    Mar 15, 2008
    395
    JT
    Anyone haha please help
  3. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Maybe a bad starter motor? Does it do this every time?
    Alan
  4. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,540
    Charleston, SC
    Curt
    Why haven't you taken it back to the guys that did your synchos and transmission work? How long ago was it?
  5. Majin_JT
    Mar 15, 2008
    395
    JT
    Yes it does this every time , but if it's a bad starter motor why would rocking the car enable it to start
    Work was done on the car 2/3 months ago
  6. vrsurgeon
    Dec 13, 2009
    16,540
    Charleston, SC
    Curt
    Sounds like its getting "stuck" in first gear and not completely disengaing before the starter cranks. Rocking the car gets it out of first gear.
    Here's a question: when you come home and drive the car into the garage, if you pull back on both paddles to put it into neutral before turning the car off.. and then secure the ebrake (assuming your garage is level) does the same thing happen or does it crank up first go.. when you know its in neutral?
  7. Majin_JT
    Mar 15, 2008
    395
    JT
    Hello so i drove the car into the garage put it in neutral then put ebrake on turned the car off , then tried to start the car and still same problem , i had to rock the car to get it to start again
  8. Skidkid
    Skidkid F1 Veteran Owner Rossa Subscribed
    Aug 25, 2005
    9,531
    Campbell, CA
    John Zornes
    This type of behavior isn't that rare and I think Curt is on the right track. The problem is that there are a lot of possibilities here: position sensor, selector fork adjustment, bad actuator. You need to seek professional help, someone who knows the system very well.
  9. Majin_JT
    Mar 15, 2008
    395
    JT
    now later today I pulled into garage same routine this time it let me start the car but I must admit over the past phew weeks it does sound like it struggles to start maybe the battery could effect this behaviour ?
  10. Skidkid
    Aug 25, 2005
    9,531
    Campbell, CA
    John Zornes
    These are very different things. Is it struggling to start or nothing?
  11. vrsurgeon
    Dec 13, 2009
    16,540
    Charleston, SC
    Curt
    Exactly.. there's not having enough elecrical juice to turn the starter.. and then there's something blocking the starter from turning. I can't make that diagnosis over the internet :(
    Might have to take it back or get someone to look at it.
  12. Majin_JT
    Mar 15, 2008
    395
    JT
    Well today i am going to change the battery this way i can rule out the battery or not will keep you updated
  13. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,174
    JT- It is always the battery until proven otherwise. All kinds of squirrels starting late model Ferraris with marginal batteries.
