Ferrari 360 F1 won't shift out of neutral, please help | FerrariChat
Discussion in '360/430' started by viperguy, Jun 16, 2019.
  1. viperguy
    viperguy Rookie
    Feb 4, 2004
    22
    Hello, I have a 2001 Ferrari 360 F1 with a CS TCU.
    The problem I am having is the car is stuck in neutral and will not shift to any gears including reverse, Engine running or not ( Ignition on, engine off)
    With my Launch scan tool i can command the gears to change and it will shift into whatever gear for a brief sec. then immediately back to neutral. I have the actuator off the transmission and I can watch it function.
    I verified with the scan tool that the brake pedal switch is working, when I shift with paddles up or down or reverse the scan tool shows those commands are being sent to tcu.
    When I shift with the paddles, I can hear a slight humming with each pull of the paddle lever, but no shifting of the actuator.
    It sounds like the TCU is getting the commands but it doesn't like something and will not engage the actuator from the paddles, but only with the scan tool commands.
    Anyone know what the TCU looks for before shifting the actuator (ignition on engine off) other than engine lid closed, door closed, brake light switch functions proper??
    Any help would be greatly appreciated!
    I can make a video of it if that helps.
  2. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    Had a similar issue last year. Gearbox stuck in neutral.
    Turned out to be a blown fuse.
  3. viperguy
    viperguy Rookie
    Feb 4, 2004
    22
    Thank you, I'll re check all fuses.
  4. Macshop6700
    Macshop6700 Rookie
    Feb 8, 2024
    12
    Zaz
    Do you know which fuse? I removed the cluster without disconnecting the battery. Now it wont go into any gears.
  5. Macshop6700
    Macshop6700 Rookie
    Feb 8, 2024
    12
    Zaz
    Anyluck? Did you fix it and what was wrong with it? Thank you
