Ferrari 360 IMMO OFF finally a reality! | Page 10 | FerrariChat
Discussion in '360/430' started by 360trev, Jul 3, 2018.
  1. sass0
    sass0 Rookie
    Jan 17, 2023
    21
    Slovenia
    Saso M
    Hey Trev thanks for the advice.
    im not used to using Galetto any more. I actually use KTag or Kess way more (430 for example) and actually closeted my K+Dcan/Galetto cables since i used those for older diesels i recently pulled this one out just for the 360 :)
    But never had a bad experience with it and it read more then a 100 cars in its time of use. But will keep ur words in the back of my mind when reading this 7.3.
  2. Dvdw
    Dvdw Rookie
    May 27, 2021
    7
    Hengelo
    Daniël van de Weijer
    Well i very much would like to use your solution, do you have any idea how long it takes before that is available? As time is kind of a thing in this case. Or would you recommend something else to read the ecu for now?
  3. Dvdw
    Dvdw Rookie
    May 27, 2021
    7
    Hengelo
    And i do have some spare ecu's here if you need one
  4. lmkocore
    lmkocore Rookie
    Jun 13, 2023
    1
    @360trev where i can find contact with you? have small problem with 360 immo
  5. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,449
    On the Limit
    Dino
    Send a PM and he should respond. The immo delete is great.
    My CS was one of the first that failed and Trev really went above and beyond to figure it out and eventually figured out how to delete it completely in the software. Getting rid of that was one of the best things I ever did. It would have been impossible without Trev.
  6. hessank
    hessank Formula 3
    1,921
    Canada, Florida
    Fred
    Me too. I now use my key to open/lock the doors.
    Same with you Dino?
    > cause I was thinking it should be possible now to install an aftermarket keyless entry system with alarm/tracking
  7. edumiudo
    edumiudo Rookie
    Jul 7, 2023
    2
    brasil
    eduardo cesar de andradrade
    @360trev
    hello im interested in your immo off for a ferrari 360.
    but I can't call you in pm, could you help me!!
  8. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,449
    On the Limit
    Dino
    Yup..... key now. But it is possible to install an aftermarket solution. But honestly, I don't think I've ever locked it.... ever!
  9. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,449
    On the Limit
    Dino
    I'll reach out to him and ask him to check on here.
    edumiudo likes this.
  10. edumiudo
    edumiudo Rookie
    Jul 7, 2023
    2
    brasil
    hello !!!
    did you ever do immo off on your 360?
    do you have the file to share?
    Why can't I contact @360trev!!
    and I wanted to put a 360 to work for a customer who has a damaged immo box
  11. Dash_Burner
    Dash_Burner Rookie
    Nov 8, 2023
    2
    Manos Bitsaxis
    Hi there. I have a 360 in my workshop and need immo off. I am able to read both ecu files but dont know which byte to change and what to make it. Can you help mate ?
