Ferrari 360 - No coolant | FerrariChat
Discussion in 'Technical Q&A' started by Gillie321, Aug 17, 2023.
  1. Gillie321
    Gillie321 Rookie
    Jul 26, 2023
    1
    Hi,
    I recently returned to my 360 in a carpark and there was a large puddle underneath and it appears that one of the front radiators has completely failed. I noticed there was no coolant in the tank and had it towed home.
    I understand there is no coolant warning light/pressure indicator - so my question is if i didn’t notice this or if it happened while moving how would I have known?
    If there’s no coolant I take it it won’t be able to read the coolant temperature and by the time the oil temp gets high (because there’s no coolant) is it not already too late?
    Any thoughts would be appreciated as i’m a bit worried if it happens again!
  2. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    Generally there will be signs of such a leak. You will smell it, you may see some steam. It may show a high temp before everything is lost. I have had several cars loose coolant and I haven't had an unknown melt down yet. Okay, I had one client ignored everything and just drove it home. Totally ruined the engine but he knew there was an issue. It was flat 12 and the spark plug extensions melted into little oval puddles in the spark plug access holes. It was really hot. Had to replace the complete engine.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    A flat 12 engine cannot be cheap. Ouch.
  4. Ferrari Tech
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    Even in 1997, it was not cheap.
