News
Ferrari 360 Spider Light Question
Discussion in '360/430' started by Carnab, Dec 18, 2019.
  1. Carnab
    Carnab Rookie
    Feb 14, 2010
    22
    All: Can anyone advise me on type of bulb for license plate and glove box for 2002 Ferrari 360 spider....pretty simple fix obviously but just need the bulb type....Thanks.
    ShadowLAP likes this.
  3. Bob in Texas
    Bob in Texas Formula 3
    2,352
    Just East of Weird
    Bob
    I just replaced mine in my 430: I believe they are the same. I pulled one and took it to the local auto parts place and easily found the correct bulbs in LED, but they had the regular bulbs too.
    Bulb number was 6418 for the LED.
    Pull one of your bulbs and match the size.
    Sent from my iPad using Tapatalk Pro
    F1Spider likes this.
  4. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    420
    SW Suburbs of Chicago, IL
    Lawrence P.
    I have a 2003 360 Spider and have swapped out all of my bulbs with Sylvania LED's. As stated above, use 6418 for the license plate, Front Trunk and Glove Box. The interior lights are 168 or 194. I also swapped out my clock bulb for an LED and now I can read it any time of the day or night.
  5. Apollo 11
    Apollo 11 Karting
    114
    San Francisco, CA
    Randy
    What number bulb do you use for the clock?
  6. ShadowLAP
    May 15, 2017
    420
    Lawrence P.
    For the clock in my 360 Spider I ordered number 74-CWHP3: 74 LED bulb - 3SMD LED Miniature Wedge, Cool White from Super Bright Led's in St. Louis, MO. You can contact them at 866-590-3533. The bulbs are very small so patients is needed to install. Took me about an hour but it is so worth the effort. I installed them in mid-2018 so I've had a couple of Summers and as I stated earlier, I can read the clock top up or down, day or night.
    Check out their website at www.superbrightleds.com
    I've ordered from them in the past with good success before Sylvania LED's were more widely available.
    F1Spider and Apollo 11 like this.
  8. ShadowLAP
    May 15, 2017
    420
    Lawrence P.
    I thought I would post a photo of the clock with the LED bulb installed. While the photo looks very bright it is not distracting at all when driving.
    Apollo 11 and F1Spider like this.
  9. tomconte
    tomconte Formula Junior
    382
    Atlanta
    Tom Conte
    Has it made the clock any more accurate? Mine doesn't keep time with a damn.
    Husker likes this.
  10. ShadowLAP
    May 15, 2017
    420
    Lawrence P.
    Fortunately my clock is very accurate. It was just so dim that I could not read it during the day time.
  11. Gumart1
    Gumart1 Karting
    Dec 22, 2010
    117
    Highland Park, IL
    Marty
    Don't mean to hijack the thread but how do you program the 360 clock? I have a Euro Spider...not sure if is displays differently than a U.S. version but it appears like it's in 24hr army time. I will definitely be changing the bulb too!
  13. ShadowLAP
    May 15, 2017
    420
    Lawrence P.
    On my clock there are two small buttons, one on either side of the clock. Press the left button to set the hour and the right side button to set minutes. My clock is in 24 hr. format all of the time (also my preference)..
  14. ShadowLAP
    May 15, 2017
    420
    Lawrence P.
    After reading your question again, is your clock in 24 hr. format?
  15. Gumart1
    Gumart1 Karting
    Dec 22, 2010
    117
    Highland Park, IL
    Marty
    It is in the 24hr format, yes. I wasn't able to find this I'm the manual. Perhaps my buttons are not working. But odd that the clock itself works. Do you have to hold the buttons or just press each one?
  16. ShadowLAP
    May 15, 2017
    420
    Lawrence P.
    Checked my owners manual and as I read it, the clock cannot be changed. I just press the buttons to change the hours and minutes.
  17. Bob in Texas
    2,352
    Just East of Weird
    Bob
    I asked this question a couple years ago, they (360/430) are all 24 hour clocks
  18. Carnab
    Carnab Rookie
    Feb 14, 2010
    22
    Guys: Looks light the light bulb for the license plate bulb is a Sylvania 6418 12v 5w. Carnab
  19. albkid
    albkid Formula Junior
    Jul 1, 2016
    317
    Jim
