Hey guys my ferrari 360 spider has a roof malfunction. When the roof is in complete open position, it will not close! Painted lid opens yet the soft top doesn't lift! Hydraulic fluid has been checked and is full. When you remove plug from the top solinoid of the motor and plug it into the bottom solinoid the roof does lift but does not finish its cycle! Can anyone give me any feedback please!
Is this the first time it has happened? If you close it all the way will it then re-open properly? You could also have a problem with your micro switches or . Plenty of threads on that.
check the micro switch at the base of the clam shell on the lef hand side to make sure it is contacting when opened.
