FERRARI 360 SPIDER SOFT TOP ROOF HOOD HYDRAULIC LIQUID RESERVOIR HOW TO TOP IT UP | Page 4 | FerrariChat
Discussion in 'Technical Q&A' started by spiderscott, Feb 23, 2007.
  1. Silber
    Silber Karting
    Jun 6, 2014
    119
    Switzerland
    Thanks again to everyone for contributing to this thread. The screw was in tight so I had to take the reservoir out to get an extension on the allen key, and it was a bit of a fiddle getting it all back on the two hangers afterwards, but got there in the end. Interestingly, the new fluid was a clear yellow colour. I filled it to half way between the bullseye and the top of the container and after one open-close cycle it dropped to the perfect mid-point where it has now stayed after a few more cycles. Hopefully that'll be it for now and I can enjoy some crisp autumn top-down motoring!
    Thanks again, and Scott give yourself a pat on the back! Cheers
  2. Ferrari Spider
    Ferrari Spider Karting
    Jan 16, 2012
    57
    North America
    Having the same issue with my top, i can hear the pump running but no movement in the top. Going to purchase the Mercedes oil today, would 1 litre be enough?
  3. Silber
    Silber Karting
    Jun 6, 2014
    119
    Switzerland
    Yes, 1 litre is plenty.
    Just to update the thread, both my hydraulic pumps needed replacing, which was nice within a month of buying the car. At least is awesome fun and sounds rediculous with the hood down!
  4. gsworld2014
    gsworld2014 Formula 3
    Dec 23, 2014
    1,061
    South Florida
    Greg S
    Last night went to put the top down and it stopped as soon as the front opened and smoke came out of the engine bay. I stopped the car and looked to find a bunch of hydraulic fluid in the bottom pan. Does anyone know what happened here? Is it a broken hose? Or something worse. I closed the top manually with the tool and now the light stays on and if I go over 20 in the car it buzzes with a warning sound.
    I can't get the car to the shop until Monday but I want to have an idea what it is
  5. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,747
    Boston, MA
    John E. Kenney
    Yikes, that was scary. Hope it was repaired ok for you. Mine is starting to hesitate. Always closes after a couple attempts. Normally happens when you have the top down during a show, on a warm engine after a drive to the place. I think my car was stored with the top down as well. Only 2 owners before me but too much time all wrinkled up. So I have creases in the rear fairing areas and drivers side strap is getting loose. Not too bad though. Where are the plastic clips on the panel? I might heat them up with a hair dryer first, though it's plenty hot now ;)
  6. John_K_348
    Sep 20, 2013
    2,747
    Boston, MA
    John E. Kenney
    I checked the level yesterday. The plastic pins on the door edge were already broken. Car was serviced at dealer last year before I bought it. The two on the inside were fine and the weatherstrip holds the outer edge securely. The level was fine and even on the top line of max on the circle. The fluid was dark, however. I got a set of stubby Allen keys and an oil trigger can. so I think I may try and swap it out anyway. How low can you take the level in the tank without getting air in the system? I suppose it might self bleed by exercising it several times. I can check a diagram in the meantime. When my top stops, it is usually all the way down, from being closed, the cover opens, but then the top never starts it way up from fully down. I release the switch, the cover sags back down, the system beeps and throws the light, then I start it again everything whirs like it does every time, but then the top starts moving as usual. You know, it even did this on my test drive but at that point, I figured it was Italian logic circuits and character quirks. So every time it has balked, all I have to do is wait a couple seconds, try again and it works. I wonder if the straps could effect this? The only stretching I notice, is on the fairing triangle over the drivers headrest. The seam and pocket along that line is a little loose. Passenger side is fine.
  7. Pagoda1966
    Pagoda1966 Rookie
    Dec 13, 2017
    1
    Anthony Place
    Spiderscott, your legacy lives on my friend - another happy customer !
    I am not handy with the scanners and can't believe I'm sitting here having FIXED A FERRARI !
    The fluid was only a little low and I was sceptical whether this would do the trick. Half an hour to strip it down, one anxious day waiting for the Mercedes fluid to arrive, half an hour to put it back together and voila - 25 seconds and the roof is up / down !
    Against a backdrop of £17k for a new roof, if I'd put this into a garage and they'd presented me with a £2k bill, I'd have been delighted. Can you imagine how chuffed I am with a £12.66 bill and I did it myself ?!?! Next stop engine rebuild (joking of course!).
    Thanks again buddy, really appreciate you taking the time to share your experience.
  8. spiderscott
    spiderscott Formula 3
    1,654
    Ratarossa HQ UK
    Ratarossa
    Very happy that 10 years on my thread is still helping you guys out and saving you some big bills
    cheers
    Scott
  9. spiderscott
    1,654
    Ratarossa HQ UK
    Ratarossa
    Pretty impressive that its also had 44 thousand views in that time :)
    lrn2ride and gsworld2014 like this.
  10. Dan Troy
    Dan Troy Rookie
    May 27, 2018
    1
    Dan Troy
    I've had nothing but problems with my 2001 360 convertible top I had 2 different shops look at it and each time it was better and then it would slow down and stop working last summer I had a local Ferrari dealer look at it and of course you know what that costand it stopped working this week .So I filled it just like you said and the thing worked like a champ.
  11. Bob in Makiki
    Bob in Makiki Formula Junior
    May 30, 2017
    443
    Honolulu
    Hey Dan. Welcome to Ferrari Chat. There is some terrific information here. I hope you will stick around and participate. This Technical Forum is great. I think you will also find the 360 Forum to be full of good folks. Join us!
  12. Poi Dog
    Poi Dog Rookie
    Oct 16, 2017
    2
    Left Coast Florida
    The boards on the internet are great. Actually makes owning a Ferrari affordable (relatively speaking) . My issue, a slow top also, filled it up and works like a charm. Thanks guys.
  13. Serge Mallat
    Serge Mallat Rookie
    Jan 6, 2018
    9
    Serge Mallat
    I want to thank you for the detailed pictures. My top would not fold down all the way. We followed your pictures because it seems that that was the most common issue (fluid). All we did is add some of the Mercedes fluid and top worked immediately. Well done. Thank you for taking the time to take the pictures step by step. Forza Ferrari!!!!!! SeSe
  14. Dano360NC
    Dano360NC Karting
    Aug 11, 2012
    167
    Southeastern PA
    Dan
    Thank you. My visions of dollars flying out the window may have been premature. I will have to try this out.
  15. tmvatlanta
    tmvatlanta Formula Junior
    Mar 26, 2017
    371
    Covington GA
    Tam V.
    Anyone has issue of the fluid leaking? I filled it up and after just 1 closing/opening cycle, the fluid is low again. Can't find where it's leaking from. Can a Leonardo read the code or identify the problem?
  16. mello
    mello F1 Veteran
    5,041
    CA Bay Area
    Steve
    A leak is unlikely. It has happened to me when I was changing out the fluid. I have to cycle the top a few times to bleed out the air. Fill it up again as needed. Good luck.
    edit: BTW, run the engine when operating the top, so that the pump will give full head pressure to ensure a good fluid circulation.
  17. tmvatlanta
    Mar 26, 2017
    371
    Covington GA
    Tam V.
    I'll try that. Thank you
  18. Astrong16103
    Astrong16103 Rookie
    Mar 13, 2013
    13
    Detroit, MI
    Had similar hesitation problems. 2006 430. Then a big dramatic frozen-while-half-way-open moment. After a rest it wouldn’t close but at least stowed. Now it will only open until the roof section should flip forward to close to the windshield - then gives up when the motor times out. When fully open and stowed, the car flips out and beeps endlessly while driving. As it turns out - my fluid is too high when stowed. Awaiting the aforementioned fluid and will try a bleed and possibly fluid change. Anything else you guys can think of? Fingers crossed
  19. Garagem743
    Garagem743 Rookie
    Nov 13, 2019
    1
    Brazil
    Fabio Nascimento Albuquerque de Freitas
    Good afternoon,
    Can anyone help me, I need the Modena Spider 360 2004 roof disassembly and mounting procedure?
    Thank you
  20. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,214
    Twin Cities
    Tim Keseluk
    What part do you need help with? The procedures are described in both the 360 and F430 Spider Workshop Manuals. The Capote Assemblies are identical.
  21. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,214
    Twin Cities
    Tim Keseluk
    Hold onto that vision. It is possible to shovel huge amounts of money at one.
  22. freddi67
    freddi67 Rookie
    Apr 7, 2012
    3
    Wow! What a fantastic post! Thanks so much for the pics and the step by step information. Most excellent!
  23. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,738
    Memphis, TN
    I think it's safe to say that if you need to top up your reservoir, it's highly likely that one or more of your rams is leaking.
  24. 360fly
    360fly Rookie
    Sep 4, 2015
    6
    Canada
    Kevin
    I am reading this post after having my hydraulic cylinder leaking at the windscreen. Have talked to a cylinder repair shop but need to get the ram or rams out. Our cars have 6 rams it looks like. Does anyone have a step by step on to R&R these cylinders? I am assuming that I should pull and rebuild all not just the leaking one.
    Any help is appreciated.
  25. Qavion
    Qavion F1 World Champ
    11,533
    Ian Riddell
