Ferrari 360 Spider Top Problem | FerrariChat
Discussion in '360/430' started by califf, Jun 23, 2010.
  1. califf
    califf Rookie
    May 16, 2010
    30
    My spider just developed a top problem. When I let the top down the soft top goes all the way back but the painted cover will not close over it. It just stays up. The top closes fine. The hydraulic fluid for the apparatus is good. What is this, and what can I do?
  2. califf
    califf Rookie
    May 16, 2010
    30
    I looked more closely at what the top was doing and the soft top had actually not fully seated. I gave it a very slight nudge down and the painted cover came down and locked normally. Then as I put the top up the painted cover raised and the soft top got stuck again. One slight nudge up and it closed normally.
  3. Skidkid
    Skidkid F1 Veteran
    9,523
    Campbell, CA
    John Zornes
    Check the micro switches. It probably isn't getting the right signals. Another possibility is that it is slightly out of alignment so it is binding. My bet is on the micro switches.
  4. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    I occasionally experience this with my spider too. I just give the top a nice tug make sure it is folded nicely then the cover will close properly.
  5. Skidkid
    Skidkid F1 Veteran
    9,523
    Campbell, CA
    John Zornes
    One other possible cause is a marginally low battery. Remember that the top is hydraulic so you suck up a bunch of power to make it work.
  6. Pete_360
    Pete_360 Rookie
    Dec 5, 2011
    34
    Canberra Australia
    Pete Baka
    Hey guys, I’m new to all this only got my 360 a couple weeks ago.
    I have the same problem mentioned my roof doesn’t seem to go down enough and if I nudge it down then it has problems coming back up, requiring me to give it a tug.
    I have tried adjusting the micro switches with no avail, I have started to go more extreme and adjust bolts cos it feels like the roof needs to sit back more when it is lowered into its compartment.
    Would be great if I could get some advice.
    Thanks guys
  7. JaguarDriver
    JaguarDriver Karting
    176
    Atlanta, GA
    Dick Maury
    Sounds like it needs a bit more fluid pressure. As the pump is electric and voltage sensitive, I have found that putting the top up or down with the engine running works a lot better. 14 volts is better than 12.
  8. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    #8 Spitfire, Mar 23, 2012
    There are a few basic checks that you can and should do, such as fluid level for example, and weak battery, but the symptoms are quite similar to those that I experienced last year, and in my case the fix was to replace the passenger side hydraulic ram.
    All of the trouble-shooting procedures were documented in a fairly extensive thread:
    http://www.ferrarichat.com/forum/showthread.php?t=335288
    and the specific procedures that I wrote-up for ram replacement are here:
    http://www.ferrarichat.com/forum/showpost.php?p=140893487&postcount=159
  9. Pete_360
    Pete_360 Rookie
    Dec 5, 2011
    34
    Canberra Australia
    Pete Baka
    #9 Pete_360, Mar 25, 2012
    Hey guys i fixed my issues with the roof,
    So the reason why my roof wasnt closing properly was because of the middle bar on the top frame (Orange oval in pic) wasnt getting pulled back on the passange side during the closing process, causing the roof not to fold completly in its resting compartment. This was the result of the tention strap (Red Circle) being loose, i ended up sewing a new bit of elastic to the old strap and presto my roof went down with no issues.
    Not sure if anyone elses issue is the same just thought i would share.
    Cheers,
    Pete
  10. alohamickey
    alohamickey Karting
    Sep 23, 2004
    180
    San Clemente CA
    Mickey
    Thank You Pete!
    My top was doing the exact same thing, the fluid was a little low, so i followed the other thread to top it off, but after, it still would not close completely.
    So I looked at your picture and half way up I stopped it, moved that bar foward with my hand and voila, close all the way!
    My next project is to sew those little elastic things in. But at least I can enjoy the car with the top down. Just about all my elastic needs to be replaced, so its going to be a longer project than I would have liked.
  11. FTA
    FTA Formula Junior
    Aug 26, 2011
    390
    Phila., PA
    Frank T
    What years are your spiders?
  12. alohamickey
    alohamickey Karting
    Sep 23, 2004
    180
    San Clemente CA
    Mickey
    If you click on our user id, and scroll to profile, it has a list of the users cars. Assuming they updated their profile.
    It appears that we both have 2001. I just got mine a few days ago and have to work through several bugs.
    Mine needs all the elastic to be replaced. I guess 10 or 11 years is to be expected...
  13. FTA
    FTA Formula Junior
    Aug 26, 2011
    390
    Phila., PA
    Frank T
    i did see that in the profiles. sorry to bug ya with the question. i also thought it might benefit the forum if the information was readily available in the thread (future potential buyers and such)
  14. Pete_360
    Pete_360 Rookie
    Dec 5, 2011
    34
    Canberra Australia
    Pete Baka
    Hey guys sorry for the late reply. I'm glad my post helped ya, my elastics all seem to need replacement I'm gonna wait till I replace the outer roof tho. In answer to the other question yes our cars are 2001.
  15. delaney
    delaney Formula Junior
    Nov 8, 2003
    720
    Montgomery TX
    PETER DELANEY
    Bit of info on top folding.
    My top malfunctioned a couple of months ago and it was caused by the material not folding correctly. A pin on the 'H' shaped cover was catching on the material. I fixed it by stopping the top ~90% through the closing cycle and manually packing the top correctly to make sure all the creases were in the right place. Left the car for ~ 1 month with the top down just to make sure the creases were established. Seems OK now but I still watch it.
  16. therealmerc
    therealmerc Rookie
    Apr 3, 2011
    46
    My top wont go all the way down. Any advice guys about what it could be causing this?
  17. Skidkid
    Skidkid F1 Veteran
    9,523
    Campbell, CA
    John Zornes
    That system is marginally up to the task of moving the top and if it is cold it is really on the edge. I generally see this when putting the top up but no reason it isn't the same on the way down. If you haven't driven in a week or so the top may not move through the full cycle. If you start the car and let it run for a while (recharge the battery some) then cycle the top again, it should help.
    Yet another system on this car that is fairly sensitive to level of charge.
  18. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    There is a bar in the middle of the top inside the canvas cover that you can feel
    It is connected to a elastic strap, the bar suppose to move towards the rear of the car when the top begins to open but as these pos cars age the elastic strap looses their tension
    During the opening process if you manually slide the bar towards the rear the top should go down a the way
  19. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    I only open/close mine with the car started...better voltage.
  20. Hein.marais
    Hein.marais Rookie
    Jul 7, 2024
    17
    Hein
    Hi any one have a sequence for the roof my roof when opening... stop once the roof has been folded.... the lid stay open and nothing further... Suspecting the micro switch being faulty and stopping the next step or loosing position of another micro switch any other recommendations?
  21. Qavion
    Qavion F1 World Champ
    14,285
    Ian Riddell
    Use the attached guide to determine the faulty switch (see steps 9 and 10):
    Most likely the E.V/Z or E.V/A switches or a solenoid issue.
    Search the 360/430 forum for EVZ and EVA or 7Q and 8Q (the wiring diagram equivalents). You may find photos of the switches.
    You may need a scanner to observe switch behaviour. Otherwise carry out wiring checks from the Roof ECU to the switches.
    Hein.marais likes this.
  22. Qavion
    14,285
    Ian Riddell
  23. Hein.marais
    Hein.marais Rookie
    Jul 7, 2024
    17
    Hein
    Much appreciated will do that and post findings thanks very much
    Qavion likes this.
  24. Hein.marais
    Hein.marais Rookie
    Jul 7, 2024
    17
    Hein
  25. Hein.marais
    Hein.marais Rookie
    Jul 7, 2024
    17
    Hein
    Hi guys so I bought the unit to see what is the the problem I'll load the screen recordings I took while opening the roof ....but no wizer on what the problem is ... switch to open roof ... lid opens .... roof retracts ..... lid stay open and flaps don't move hydraulic keeps running .... I then push to closed roof and the all functions and the roof closes..it just don't go past the stage to close the lid and covers .... the limits are made ... being lidnooen roof in bin etc
