Ferrari 360 spider top pump reversing | FerrariChat
Discussion in 'Technical Q&A' started by fullspeed, Nov 20, 2018.
  1. fullspeed
    fullspeed Rookie
    Dec 17, 2015
    14
    Does anyone know how the 360 top system actually works? I am trying to figure out if up vs down is just a matter of the pump motor polarity being reversed like it is in many cars. Any help much appreciated. Thanks
  2. fullspeed
    fullspeed Rookie
    Dec 17, 2015
    14
    Ok maybe someone can point me towards the spider top service manual. I have both the modena workshop manuals but can't seem to find the one for the spider top. There is no mention of the top in those manuals
  3. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    It has a valve switching system. The pump just makes pressure. It is actually set up to use fluid in one area and return it from another so the amount of fluid stays pretty level in the reservoir.
    What is the issue you are facing? I am working on a 360 top right now.
    Qavion likes this.
  4. fullspeed
    fullspeed Rookie
    Dec 17, 2015
    14
    I had the top begin to go up and the flaps did not retract. Now trying to get it to reverse back down but it just beeps. So i was trying to go around the top computer and force the reversal.
  5. Motob
    Motob Formula 3 Professional Ferrari Technician
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    One of the micro-switches that informs the top ECU the position of everything may be malfunctioning. The top ECU stops the top from running if there is a conflict between these inputs. It does this to keep parts of the top from hitting and damaging each other. A Ferrari specific diagnostic computer will let you see the positions of all of the top micro-switches to give you help in diagnosing the cause of the problem. I would not try forcing anything.
    Jamarico likes this.
  6. 2NA
    2NA F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The flaps aren't hydraulic. They have their own motor that operates a pair of cables.
    tbakowsky likes this.
