Ferrari 360 Transmission Synchro repair | FerrariChat
Discussion in '360/430' started by mvaldezf60, Sep 4, 2024.
  1. mvaldezf60
    mvaldezf60 Karting
    Feb 16, 2009
    193
    California
    Hello all, I am looking for a shop/mechanic who can work on the 360 Modena transmission in California (preferably Northern California/central coast.) I believe that my 1st gear synchro was damaged after the heat exchanger failed during the previous ownership. Other than that, the transmission now shifts much, much better thank you to the help of a fellow Fchatter. Before it had issues dropping out of gear into neutral in random gears. Now that problem, no longer exists thanks to help from Flash32. I am going to try a new gear oil for now but want to start planning on a repair at a shop during winter. Thank you in advance!
    flash32 likes this.
  2. sammyf
    sammyf Karting
    Aug 13, 2004
    231
    Northern California
    mvaldezf60 likes this.
  3. mvaldezf60
    mvaldezf60 Karting
    Feb 16, 2009
    193
    California
    Thank you for the info, however, ive troed calling them and visiting there site for more info but was unable to reach them or understand their site. The entire site was in a different language.
  4. DiSomma6
    DiSomma6 Karting
    Nov 27, 2023
    82
    Erik
    You mentioned it was the 1st gear syncro - do you have trouble getting it into first from a stop (N) or on downshift from second? This is on a F1, correct?
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,964
    San Carlos, CA
    Mitchell Le
    So what are your symptoms?
  6. mvaldezf60
    mvaldezf60 Karting
    Feb 16, 2009
    193
    California
    Yes this is an F1 system, it will usually go into 1st from N on a stop, but on a rare occasion will skip 1st gear from N and go straight to 2nd. I know I also need to adjust PIS, (currently at 5.6) but I am working on that separately as my scan tool is having trouble making that adjustment. It will go into 1st from 2nd on downshifts however, this is usually accompanied by a a "crunch" noise. Noise only happens from 2nd to 1st shifts.
  7. GogglesPisano
    GogglesPisano Formula 3
    1,850
    East Bay, California
    Joe
    Might have gone out of business. I would maybe send them an email? The site is a budget word press or something similar. The funny words you see are placeholders for actual text. Basically means they started making their site but they never finished it. Not sure if that's indicative of their work :D
    Google maps says that's a motorcycle shop now and there's zero about them if you search so not promising.
  8. imahorse
    imahorse F1 Rookie
    3,620
    WI
    Dustin
  9. Qavion
    Qavion F1 World Champ
    12,489
    Ian Riddell
    It's a pity Hill Engineering UK aren't making synchros for later model cars
    https://www.hillengineering.co.uk/gearbox-parts/synchro-related
    They are open to suggestions, but the gestation period takes some time and I guess they would need a semi decent sample
    mvaldezf60 and imahorse like this.
  10. imahorse
    imahorse F1 Rookie
    3,620
    WI
    Dustin
    mvaldezf60 and Qavion like this.
  11. mvaldezf60
    mvaldezf60 Karting
    Feb 16, 2009
    193
    California
    Hopefully there is another option if Synchros aren't available, outside of replacing the transmission altogether.
  12. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,664
    San Jose, California
    #12 SoftwareDrone, Sep 6, 2024
    Forget about the broken website. Call Carl (1-209-810-6501). He will help. If he doesn't reply, I will call him. He recently injured his foot and has been out of commission. He is back in the shop now and is currently working on Ferrari transmissions as I write this.
  13. mvaldezf60
    mvaldezf60 Karting
    Feb 16, 2009
    193
    California
    Thank you for the contact info!!! I will call him first thing Monday. Much appreciated!
  14. Senshi458
    Senshi458 Formula Junior
    622
    Norway
    Reza
    I had ALL my synchros + gears changed OEM new from Ferrari some I heard from AV Engineering was the last made from Ferrari and not possible to make them anymore. Even the coil cooler something in the transmission got changed... I did not know 360 had this big issue with synchros + gears. My 360 is manual and have around 32k KM!!!
