Ferrari 360- upgraded ECUs...can we use battery cutoff switch? | FerrariChat
Discussion in 'Technical Q&A' started by jpcantabile, Aug 31, 2018.
  1. jpcantabile
    jpcantabile Rookie
    Aug 31, 2018
    1
    Jennifer Piacenti
    Hi-
    We had the ECU upgraded when we purchased our 2001 Ferrari 360 and we were told this meant we could not use the battery cutoff switch. Does any one know if this is true? We need to be able to leave the car for a while without a trickle charge.
    Thanks!
    J
  2. MD355
    MD355 Formula Junior
    Mar 8, 2004
    802
    Athens, Greece
    MD
    I am not sure here, but I think that the ECU is ROM memory, which means that when it is flashed, it stays like this forever, with or without electric power... If it was RAM memory, I guess it would erase once you turn on/off power...
  3. eric355
    eric355 Formula 3
    1,210
    Toulouse (France)
    Eric DECOUX
    BS !!
    Of course you can use the battery cutoff switch. No risk for the ECUs even if they have been "upgraded".
