Ferrari 365/400/412 Timing Chain Replacement | FerrariChat
Discussion in 'Technical Q&A' started by 360modena2003, Mar 21, 2022.
  1. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,460
    I will need to replace the timing chain, as there is excessive play. I have already ordered a new one and should get it next week.
    My question: Can the new chain be linked with the old one on these engines and "fed" through to replace it OR does the timing chest need to come off?
    Sent from my MAR-LX1M using Tapatalk
  2. wmuno
    wmuno Formula Junior
    522
    Wilmette, Illinois
    Bill Muno
    Have you checked the chain tensioner? There is an adjustment screw and lock nut to remove any excess play. Although unlikely, the spring in the tensioner might have broken.
  3. 360modena2003
    Jul 11, 2009
    2,460
    I am trying to get to the adjuster now, it seems it is only possible by removing both alternators, do you know how it is done?
  4. wmuno
    522
    Wilmette, Illinois
    Bill Muno
    No, I have never work on this car. On the 330's and early 365's there is clear access to the tensioner on front passenger side of the engine.
  5. 360modena2003
    Jul 11, 2009
    2,460
    It seems I may have to remove the engjne...
  6. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,233
    Georgia
    Wade Williams
    You will need to remove the timing case for the chain replacement.
  7. Rifledriver
    37,288
    Why?
    I have done them a bunch of times and never resorted to that.
  8. 360modena2003
    Jul 11, 2009
    2,460
    Can it be done with the engine in place?
  9. Rifledriver
    37,288
    Easily. The cars are getting old so as good a look as possible at chain guides is advisable. Ferrari recommended due to its length replacing them every 40,000 kilometres so we did it frequently. If have done it with cams in but only once and will not again. Too hard, slow and labor intensive not to mention risky.. Remove cams 1st. One person turns motor via socket on front pulley. One person pulls old chain and feeds new chain once connected together.
  10. wmuno
    522
    Wilmette, Illinois
    Bill Muno
    If you remove the cams, won't the drive gears fall down into the timing case? Do you mean "remove the rocker arms" so the cams turn with much less friction?
  11. tazandjan
    39,318
    Bill- There are no rocker arms on the 365 GTC/4, GT4 2+2, 400, or 412 engines.
  12. wmuno
    522
    Wilmette, Illinois
    Bill Muno
    OK; I am familiar with this design. I had it on my my 4 cylinder Fiat 124. The cam lobes operate directly on adjustment shims. I still have a box of them.
