Buy
Ferrari 365GT 2+2
Discussion in 'Vintage (thru 365 GTC4)' started by Bowzer, May 28, 2020.
  1. Bowzer
    Bowzer Formula Junior
    Aug 3, 2016
    334
    MALTA
    Marcus
    Hello all,
    I need to unscrew the plastic grilles ( heat vents) from on top of the front fenders.
    The 4 screws will not screw off, and turn with no upward success.
    Are these accessible from the bottom side maybe there are rusted bolts at the bottom ?
    Thank you for your help.
  3. 12659
    12659 Formula Junior
    Oct 6, 2005
    329
    Seattle WA. USA
    mark
    Those vents are not plastic, some kind of cast metal. The 4 screws fasten to a metal flange in the top of the fender. If the screws are damaged or
    rusted in place you might need to carefully drill them. If you run your hand along the inside surface of the fender (carefully) you can feel the tips of the screws.
    Replace with stainless steel.
    Pmo75 likes this.
  4. 12659
    Oct 6, 2005
    329
    Seattle WA. USA
    mark
    P.S. Look closely at the vent at the top and you will find the location of the screws. They are hidden in the vanes of the vent.
  5. Bowzer
    Aug 3, 2016
    334
    MALTA
    Marcus
    #4 Bowzer, May 29, 2020
    Thank you Mark.
    "If you run your hand along the inside surface of the fender (carefully) you can feel the tips of the screws."
    Where do I put my hand through to reach the inside of the fender, I know there is an inspection panel that is unscrewed towards the front of the fender. is there another inspection panel to the rear to be able to reach these grilles from beneath?
    Thank you
