Ferrari 400/412 Cooling System Bleeding | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by 360modena2003, Mar 19, 2022.
  1. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,438
    Hello,
    other than the 15mm mentioned in the owner's manual, is there a bleed screw or any particular process to ensure the cooling system is completely full and air free?
    Should one fill the header tank as well?
    Sent from my MAR-LX1M using Tapatalk
  2. raemin
    raemin Formula 3
    Jan 16, 2007
    2,346
    Lyon (FR)
    R. Emin
    There is a huge volume of coolant, bleeding not necessary.
  3. Rifledriver
    37,105
    No such thing as an automobile cooling system that is completely full and air free. It simply cannot operate that way. If you do not leave air space in proportion to its coolant capacity it will make it for you.
  4. 360modena2003
    Jul 11, 2009
    2,438
    Yes, I assume that is accounted for in the mentioned 15mm coolant level.
    I had the radiator emptied, but only 10/12 liters came out, and a similar amount went it, heating core?
  5. Steve Magnusson
    26,825
    #5 Steve Magnusson, Mar 19, 2022
  6. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    360
    The "overflow" tank should remain empty all of the time, unless you overheat and vapor forces coolant in there.
    Also, the pressure cap goes on the "overflow" tank and the non-pressure cap goes on the radiator. I had it backwards for a couple of years.
    Ken
    Schumi and 360modena2003 like this.
