Ferrari 400i/412 All Engine Wiring | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by 360modena2003, May 22, 2022.
  1. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,437
    Hello,
    the engine is finally in, now I need to sort out all the wiring.
    Can someone confirm if the connector going to the air flow sensor (see attached picture) is brown?
    Blue = cold start injector
    Black= Aux air valve
    Grey = WUR
    Large Black = TPS
    Small square brown = ECU Engine temp
    Black and white pair = CPS
    Small connector: oil warning switch (at the oil filter base)
    Larger connector = oil pressure sensor
    Engine temp gauge sensor = HAVE NOT FOUND IT
    Down in the oil sump, right side: Oil temp sensor
    Sent from my MAR-LX1M using Tapatalk
  2. raemin
    raemin Formula 3
    Jan 16, 2007
    2,339
    Lyon (FR)
    R. Emin
    Not sure about the plug colour, but the cables should be
    - white and red on the TT switch
    - black and orange on the cold start injector
    - purple black on the airflow sensor
  3. 360modena2003
    Jul 11, 2009
    2,437
    Great, thank you.
  4. 360modena2003
    Jul 11, 2009
    2,437
    Updates:
    Engine temp sensor for the gauge: small spade connector, in the right bank cylinder head.
  5. 360modena2003
    Jul 11, 2009
    2,437
    Air flow sensor= Brown connector (only one, driver side on LHD cars).
  6. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    That’s correct. Also, when it’s unplugged and the ignition is turned on, the fuel pumps run continuously.
