Ferrari 400i part urgently required: retainer for rear spring | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by christc, Jun 22, 2019.
  1. christc
    christc Formula Junior
    BANNED Silver Subscribed
    Mar 3, 2013
    470
    Germany
  2. OttoB
    OttoB Formula Junior
    Aug 17, 2013
    714
    Palm Beach, FL
    A machinist could fabricate one for you, which would likely hold up better than a used one (or if any ‘new’ ones lying around a shelf these past almost 40 years), no?
  3. christc
    Mar 3, 2013
    470
    Germany
    That is my secong option. The ring is not as simple as it looks. Beside several phases it has a ring groove wich is vital as a 1mm wire sets into it holding the ring in place.
    So if I can get an original one I go for it, if not it is the lathe option...
    Christopher
  4. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    Christopher
    I do not think these are special for our cars in spite of us having hydraulic suspension. The spring perches should be the same for all Koni's with same spring ID/OD (mainly ID). Koni tech service in Holland is usually quite helpful even if they will not rebuild our shocks. Otherwise a search of alternate cars with same diameter spring should turn up the Koni part, even if you had to buy a new shock.
    I am surprised about the wire retainer. I have changed my rear shocks and did not have this feature on the spring perches, they are just held in place by the springs.
    Ken
  5. 15765
    15765 Formula Junior
    May 14, 2012
    302
    Las Vegas NV
    Chuck King
    Simply make a full circle new one using your sample in a lathe with the groove/s you need and cut in half.
    Chuck
  6. 365boxer
    365boxer Formula Junior
    Sep 30, 2004
    404
    La Drova, Spain
    Nick
    Have you asked Jurgen at italspares, he is n Germany and he is dismantling a 400i,
    Nick
  7. christc
    Mar 3, 2013
    470
    Germany
    Dear All,
    I meanwhile had one made by a machinist. Hope it will work out. I still have to install it when I get the new gas spheres for the rear axle.
    Thanks for all your suggestions and help.
    Christopher
  8. Ak Jim
    Ak Jim F1 Veteran
    9,638
    North Pole AK
    Post some pictures please.
  9. christc
    Mar 3, 2013
    470
    Germany
    Will do so when I get the gas spheres...
    Il Tifoso and Ak Jim like this.
