Ferrari 412 Cylinder Compression Test | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by 360modena2003, Jan 17, 2022.
  1. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,437
    Another box ticked off my list.
    The compression is very healthy, what is considered "normal" for the 412?
    I opened the throttle plate to WOT, disconnected both fuel pumps and also disconnected the multiplex ignition controler under the steering wheel (this is done to avoid any possible damage occuring to the ECU when the spark plug is not grounded). Image Unavailable, Please Login
    Sent from my MAR-LX1M using Tapatalk
  2. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,642
    SF Bay Area, CA
    Ruben
    I’m by no means an expert, but have heard that this is highly variable based on the gauge utilized as well as the state of the battery, so an absolute number is not really meaningful. Rather, what is important, is consistency across all 12 cylinders… the rule of thumb being no more than 10% deviation across all.
    Ruben
    of2worlds likes this.
  3. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    Ruben is correct. There is no actual correct pressure number. Cam timing has a big influence on pressure as well as many other things. So, consistency is key. 10% is a good rule of thumb. You are just looking for something way off. I have had engines that are 210 ish on one bank and 175 ish on the other. It was corrected with proper cam timing.
    If you are 190 ish on all 12, good for you. Proceed with a smile.
    wrxmike and of2worlds like this.
  4. Rifledriver
    37,099
    On a 12 cylinder always have a jumper battery connected. It would be the rare battery that maintained good consistent cranking speed for all 12 cylinders.
  5. 360modena2003
    Jul 11, 2009
    2,437
    With all spark plugs removed the battery had no problem cranking all 12.
