Ok, just measured. Seems it is getting around 700ccm3/30 sec. Will compare the other bank before I take apart the pump. Sent from my MAR-LX1M using Tapatalk
I measured the pressure with the WUR blocked off and got around 5 BAR - according to the 400i manual, primary pressure should be between 5.2 and 5.8 BAR. I do not know if the 412 has different readings. But flow is definitely not 850ccm3.
There is a slight pressure difference for sure. I would indeed suspect a slightly weak electric supply (with a runing engine you the alterntors would compensate the voltage drop, which the battery alone cannot) , but this would not justify that the bank is starving at idle. As you get 700cc out it means there is more than enough supply for idle. Now you should check control pressure. Also it could be a good idea to let the pump run for 15min so as to cycle fluid in the system and clear the crude that might be left. On the Porsche 928 website he recommends to do this with a can of carb cleaner in the tank. Once the gazoline has cleared the system, you could try to check and adjust the pressure. (A few months ago, I've posted the receipe in order to make your own carb cleaner. It's a mix of kerosene synthetic thinner and wd40).
Yes, at idle the difference is very obvious - seems like the pressure reaching the injectors is insufficient. Perhaps I need to remove the metering head and inspect.
I measured the amount of fuel on the other bank, and also around 700 per 30sec. Next up I will measure the pressure at the fuel pump line and on the metering head (system pressure). The temperature, sound and smell of the exhaust of the two banks remains very different - the "weak" side barely has any scent to it and silent, the other side it hot, loud. Something is way off... Sent from my MAR-LX1M using Tapatalk
UPDATE. It seems I have found the culprit. Does this diaphragm look normal/new? I bought a complete rebuild kit and it was installed in March of this year. The engine has only been running since August. Take a close look at the ceramic plate. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Sent from my MAR-LX1M using Tapatalk
Give a try to the SAVOX. They have been working flawlessly for me, even with E10 (10% ethanol). I had to punch an additional hole that did not line up but the material is up to the task. I do not mean to beat a dead horse, but your original gaskets did look better and the head was absolutely pristine. "While you are there" unnecessary fixes may cost much more than planned.
The seller just replied and said they look "good/normal". Can anyone confirm that this how they should look? The reason I replaced them was because the car was running very badly, (right) after replacement it ran incredibly well. My theory is that they deformed over time, and now the amount of fuel reaching the ports is inconsistent. Even the spray pattern at the injectors has changed noticeably.
If there is no hole in the membrane then it is fine. Did you clean the tanks, the WUR and all the mesh-screens of the k-jet? As I've said earlier It is quite possible that some crude is now flowing in the system. K-jet are hard to tune for this reason: once you've made your rebuild, you tune it to perfection then suddenly gazoline cleans the mesh screens which lowers the control pressure (so one more tuning session), and shortly after that the crude accumulated somewhere get dislodged and makes another mess. The uneven spray pattern would suggest this is your issue. So you've got to clean as much as you can, then let the pump run with carb cleaner for quite a while (engine off) and once this is done you start the engine with so-so settings, let the engine heat up the gasoline, which makes it an excellent cleaner for the system (if the engine is idling, lots of hot gasoline gets back in the tank ). Once it has been running for an hour or so then you can start fine tuning the k-jet. Once everything runs again put new filter shortly after (Mahle filters are cheap).
There are no holes, but it looks very deformed. These are virtually brand new. If the membrane is too "lose" it could interfere with the flow to the port and not allow the pressure differential between the upper and lower half to work correctly. Image Unavailable, Please Login Image Unavailable, Please Login Sent from my MAR-LX1M using Tapatalk
As a reminder, I had the tanks completely flushed and cleaned prior to installing the metering heads. Sent from my MAR-LX1M using Tapatalk
