Ferrari 412 K Jet Air Flow Sensor Electrical Connector | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by 360modena2003, Dec 20, 2021.
  1. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,435
  2. raemin
    raemin Formula 3
    Jan 16, 2007
    2,298
    Lyon (FR)
    R. Emin
    That's the normal setup: whenever the airflow sensor is shut (i.e the engine does not breath air), this switch will deactivate the relay pumps, which is meant to avoid the high flow k-jet pumps to split litres of gasoline all over the place after an accident.
    This safety mechanism induces additional complexity in the system that can be troublesome: during startup the engine does not breath air, so whenever the engine is cold, the thermo-time switch will override the safety mechanism and activate the pumps for up to 7~12 seconds. Then what happens when you want to crank the engine when it's hot? The thermo-time switch does not operate so we have to rely on the accumulators that are holding fuel and pressure for roughly one hour.
    All in all if your thermo-time switch is bad or the accumulator are leaky, or if the seals of the valve pressure regulator are shot you will not be in a position to crank the engine, and your only solution will be to force the pump to operate (= disconnect the green plug you've just discovered).
  3. raemin
    raemin Formula 3
    Jan 16, 2007
    2,298
    Lyon (FR)
    R. Emin
    By the way, where did you get this red headed 412? There are not so many that I know of. The two I've come across would definitively not need an engine out.
  4. 360modena2003
    Jul 11, 2009
    2,435
    Are you saying that the red head is original? I do not think so.
    Once I remove and inspect the timing I will decide if I remove the engine.
    The idea is also do to an "aesthetical" restoration of the engine bay; send all parts to get re-plated, paint the chassis, repaint the heads in correct black, media blast everything, etc.
    Sent from my MAR-LX1M using Tapatalk
  5. raemin
    raemin Formula 3
    Jan 16, 2007
    2,298
    Lyon (FR)
    R. Emin
    #5 raemin, Dec 20, 2021
    No paint on the 412: unlike the others that had black wrinkle paint the 412 had unpainted heads. So if you paint the head it will not be original either.
    My brother had such a 412 with red heads. He got it from a friend who had two grey manual 412 and who decided that both would look better with painted heads. He finally came to the conclusion that having two identical 412 was hard to justify, so sold one to my brother.
    Red heads can be nice depending on the car colour combo: a grey/black 412 with red interior can be nice "red headed". I would not say so for other colours.
  6. 360modena2003
    Jul 11, 2009
    2,435
    One 412 is very justifiable! I am really liking it.
    I look more closely at pictures on the web and found that in fact the connector is only on the drivers side.
    I didn't know that the bonnet is also opened via an electrical switch! Very sofisticate! Mine isn't working, will have to take a look together with the fuel cap and rear trunk.
    Are the wiring diagram available on pdf for the 412?
  7. raemin
    raemin Formula 3
    Jan 16, 2007
    2,298
    Lyon (FR)
    R. Emin
    I don't think anybody shared these diagrams here and that's really frustrating: once the electricity is sorted out these cars are a real pleasure.
    So no free sources for the 412 electrical diagram... Unfortunately the diagram you can buy will be "factory quality" at best, that is to say nowhere near what Paul Bennet has been offering for the 400.
    Rear trunk mechanism could be found in old Cadillacs (there is a thread on the subject), but no idea regarding proper substitutes for the actuators used on the bonnet and fuel cap.
  8. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,589
    Argent/Brasil
    Guido
    This is for free !! The internal diagram for your fuse boards. Its in mirror view en split in 2 for more clearness. Happy New Year and enjoy you cars in 2022.
    360modena2003 likes this.
  9. Steve Magnusson
    26,599
  10. 360modena2003
    Jul 11, 2009
    2,435
    Could you send me this in a pdf format?
    I have a number of things that are not working...
  11. Steve Magnusson
    26,599
    No, I don't have one to scan, and I don't recall anyone here ever saying that they have it in pdf format (nor offering to share it). If you do get a pdf copy, please share it with us.
  12. 360modena2003
    Jul 11, 2009
    2,435
    I was referring to the diagram shared - see post #8.
  13. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,674
    Romulus, NY (Finger Lakes)
    Ken Battle
    360
    I have struggled with the three push buttons for hood, trunk and fuel cap. The problem can be the switch; contacts burn out. Switches are available but getting pricey. More often thew electrical connector on bottom of switch has bad contacts that can be cleaned and reinstalled. Also, check contacts on the solenoid under the hood if you have been doing work back there; its close to firewall behind the wiper levers. Mine all working regularly now.
    Ken
  14. 360modena2003
    Jul 11, 2009
    2,435
    Thank you, will start with the buttons and go from there.
  15. Rifledriver
    36,819
    Fuel pumps should run with starter. Residual pressure is not expected to start car.
