Ferrari 412 Oil Filter Base O-Rings | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by 360modena2003, Dec 19, 2021.
  1. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,435
    Are the o-rings #25 and #26 the ones that can fail and cause oil/water mixture?
    Where are the water passages here?
    Thank you Image Unavailable, Please Login
    Sent from my MAR-LX1M using Tapatalk
  2. Al Campbell
    Al Campbell Formula Junior
    Nov 22, 2013
    581
    Australia
    Yes 25 and 26 are the ones.
    Coolant flows around the outside of tubes 24 and 27 between o-rings 25 and 26 while oil flows through tubes 24 and 27.
  3. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,675
    Romulus, NY (Finger Lakes)
    Ken Battle
    Getting old tubes out is quite difficult, maybe less so if doing a rebuild. I did a homemade tool to use as a puller.
    Ken
  4. Tojo
    Tojo Formula Junior
    Apr 12, 2002
    499
    Tim
    Yes can be hard to get them out especially if they’ve been there forever. I bought a kit like this https://www.amazon.com.au/WINMAX-TOOLS-AUTOMOTIVE-Internal-Extractor/dp/B017XDLDDY and needed to grind down one of the pullers so it would go deep enough into the rear tube to get a grip on it
  5. SouthJersey400i
    Mar 14, 2007
    1,675
    Ken Battle
    Tojo
    Nice "kit". I had some similar bits but in any case they had to be modified to the the small. long hole you are working in.
    Ken
  6. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    32,983
    MA
    If you decide to change them yourself, keep very good track of which part number goes in each position. Once they are out of the bag, it was basically impossible for me to tell visually which was which and it matters.
    Schumi and Il Tifoso like this.
  7. 360modena2003
    Jul 11, 2009
    2,435
    Great, thank you.
    I will take many pictures and post them to keep track.
  8. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,669
  9. SouthJersey400i
    Mar 14, 2007
    1,675
    Ken Battle
    The tread above has a nice picture of a homemade tool similar to what I used.
    Ken
    360modena2003 likes this.
