Ferrari 412 Timing Chain Control/Cover Removal | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by 360modena2003, Jan 9, 2022.
  1. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,438
    I started on my "check list", the adjuster bolt seems to have plenty of adjustment left.
    The question now is what do I need to do to remove the timing cover? I have already removed the acorn nuts and WUR.
    Is there anything else that needs to come off? It isn't moving at all.
    Sent from my MAR-LX1M using Tapatalk
  2. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    See if there is one bolt in the front. Not sure.
  3. 360modena2003
    Jul 11, 2009
    2,438
    It is moving now, thanks.
    Its the glue they used that is making it difficult.
  4. 360modena2003
    Jul 11, 2009
    2,438
    Got it off. The o-rings were glued on.
    Seems like it has been replaced before.
    Barely has any play. Image Unavailable, Please Login
  5. Al Campbell
    Al Campbell Formula Junior
    Nov 22, 2013
    581
    Australia
    The O-rings at the back should be cut at the top so when the cover is re-installed (slide O-rings into groove as cover is lowered) they need a small amount of sealer to seal them.
  6. 360modena2003
    Jul 11, 2009
    2,438
    Thank you.
