Ferrari 458 - Starting/Running Issue | FerrariChat
Discussion in '458 Italia/488/F8' started by Dodger, Aug 9, 2016.
  1. Dodger
    Dodger Rookie
    Jan 17, 2014
    13
    After leaving my 458 in my apartment (second home) garage for almost two months. Being on a trickle, it fired up willingly, revving easily, but when I paddled into first, the engine died. Feathering the gas was useless as the rpm's continued to drop until they reached 400, and then 0. Several more attempts resulted in the same. Ferrari Roadside assistance arrived and simply drove the car out of the space, like the achy tooth at the dentist.
    I drove the car, which was then running well to the local Ferrari dealership whose diagnostic testing showed nothing wrong. The next time I drove it, I just put it into first and immediately drove out of the space as the roadside assistance representative had done. Everything seemed fine.
    I did not drive the car again for another month. At that time, I allowed it to idle for 30 or so seconds before driving out of the space. When I tried to move the car, the problem, failing to continue running, repeated itself, and it died half in and half out of the space. Several attempts to restart resulted in the engine running then dying, but I was ultimately able to utilize the few 100 rpm's available to nurse it the eight feet back into the space.
    The space is on a sideways incline with the entire driver's side being at a level of about 6-9" above the entire passenger's side. The gas tank is 1/2 full. I would value any insight into this problem and a cure. I wonder if: (i) the gas in the tank is inferior; (2) the gas tank has water in it; (iii) the injectors have become clogged; (iv) an automatic fuel management system, if any, is malfunctioning; or (v) the angle at which the car is parked leaves the engine unable to suck out sufficient fuel until it is driven away from the incline?
  2. chefcore
    chefcore Karting
    May 8, 2014
    67
    Virginia
    I see this is your first post. Did you meant to put this in the classifieds? Might get a better answer in the 458 forum: 458 Italia/488 - FerrariChat.com
    HTH
  3. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    Yep, I think this is posted in the wrong place.
    You can ask the Moderators to move it to the 458 section for you.
    Just click on the red triangle (with the "!" in it) on the upper right of your first post and ask them to please move the thread.
    As far as your 458 issue, I've never had a problem like that.
    I have 11,000 miles on my 2011 458.
    You might try parking it on a level parking space and see if the problem never happens again.
    If that works, then maybe build your own custom set of one-sided tire ramps to raise the lower side of your car so that it sits relatively level in your parking spot?
  4. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    39,990
    Huntsville, AL., USA
    Andrew
    Thread moved to the right place. Welcome to FerrariChat! :)
    All the best,
    Andrew.
  5. spiders
    spiders Formula Junior
    Jun 8, 2012
    474
    How long has the present gasoline been in the tank? You may have an old fuel issue.
  6. RayJohns
    RayJohns F1 Veteran
    7,919
    West Coast
    Ray
    #6 RayJohns, Aug 11, 2016
    There is a hose which connects both sides of the fuel tank - however, there is also a fuel pump on each side.
    Have you confirmed if both fuel pumps are functioning? I think if one pump has failed and gas is flowing over to one side of the tank (while parked), you might run into the symptom you are describing.
    Not sure, but I would think a failed fuel pump would trip some sort of code.
    I believe there are also two fuel filters involved. Might not hurt to have those inspected.
    Ray
  7. Dodger
    Dodger Rookie
    Jan 17, 2014
    13
    I would like to thank all who responded and tried to assist. I have solved the problem. The car sits on an incline in an underground garage. Once it is off the incline, it runs perfectly!
