488 - Ferrari 488 oil leak around Drain plug | FerrariChat
488 Ferrari 488 oil leak around Drain plug
Discussion in '458 Italia/488/F8' started by Jrachetta, Feb 13, 2024.
  1. Jrachetta
    Jrachetta Karting
    Feb 13, 2024
    59
    Syracuse, NY
    Jon Rachetta
  2. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,985
    St. Louis, MO
    Eric
    Re torque or change drain plug / seal
  3. up4speed
    up4speed F1 Rookie
    3,649
    Long Island, NY
    Chris
    It's hard to say by looking at the photo. Hopefully just the seal on the drain bolt. But if not, it's very easy and fairly cheap to replace the whole bottom of the oil tank and pipes associated, so it shouldn't be too bad. Start with the seal on the drain plug, and see what happens.
  4. Jrachetta
    Jrachetta Karting
    Feb 13, 2024
    59
    Syracuse, NY
    Jon Rachetta
    thank you. Apparently the bolt wasnt tight enough. They cleaned it up, torqued the bolt, drove it around and nothing there. Hopefully it stays, if not it doesn't appear to be a big deal like you mentioned.
    up4speed and Eric C like this.
