Ferrari 550 - door stop / check strap 61508500 | FerrariChat
Discussion in '456/550/575' started by 275GTB, May 29, 2024.
  1. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    Morning, when opening the doors on my 550, it just feels they open to far! to the point where I am worried that the leading edge is going to get damaged in the door shut / hinge side.
    I am sure i have read somewhere years ago about a door strap issue on the 550, but cant find the thread anywhere?
    and guidance, help or upgrade advice very much appreciated.
    thanks
    Mark
  2. pkl03
    pkl03 Formula Junior
    540
    Sydney, Australia
    Peter
  3. ///Mink
    ///Mink Formula Junior
    820
    Fair Oaks, CA
    Tom Mink
    I had a similar problem years ago. I had to replace the check rod assembly (65195200) and the "SX plate door" (63895300). One of the studs on the check rod had broken and the plate had also broken in half and the lower bit fell out. Not sure which was first to fail.
    I replaced both and it's been perfect for many years.
    Auraraptor and pkl03 like this.
  4. marce
    marce Formula Junior
    Jan 30, 2014
    454
    Australia
    Marcel
    the part pictured #56(vertical pin) needed replacing, the mechanic noted that the long heavy doors are too much for the parts, just don't open the doors all the way, was the advice
  5. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    thanks folks, for some reason I had it in my head that someone on Ferrarichat had made an upgraded part to solve this problem, I may be wrong
  6. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,986
    MO
    Omar
    #6 Auraraptor, May 30, 2024
    Its important to replace the pins whenever playing / adjusting with door alignment as they wear out over time
    275GTB likes this.
  7. Auraraptor
    Sep 25, 2002
    13,986
    MO
    Omar
    For quick reference, 66842800 is the door pin PN.
  8. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    many thanks
