ferrari 575m acceleration problems | FerrariChat
Discussion in 'Technical Q&A' started by ferrari_89, May 1, 2009.
  1. ferrari_89
    ferrari_89 Rookie
    Aug 17, 2008
    17
    Dallas Texas
    Nicky Kaba
    The car accelerates to 4000rpm, and then it bogs. Will not accelerate past 4000rpm's. Please Help.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #2 ernie, May 1, 2009
    Have you checked to make sure the gas pedal isn't getting hung up on the floor mat?
    If that checks out have a look at the connections for the mass air flow sensors. Make sure that they are clean, the wires are in good condition, and connected properly.
    Also how about misfiring? Does it sputter or just bog down? Have you gotten a check engine light? Have you pulled the codes to see what is stored?
  3. kens
    kens Formula 3
    1,336
    I suspect the mass air flow sensors. I am familiar with Bosch MAF sensors that can be unplugged and successfully run in limp home mode. Unplugging the air flow sensor can quickly prove or disprove that this is the problem.
    I do have personal experience with acceleration stalling out at 4000 RPM due to the air flow sensor.
