Ferrari 599 radio cover | FerrariChat
Discussion in '612/599' started by Ferrariuk599, Feb 22, 2014.
  1. Ferrariuk599
    Ferrariuk599 Rookie
    Feb 22, 2014
    3
    Help someone can help I just bought a 2007 599 and the carbon radio cover will not stay closed am I missing something or is this common problem and does any one know a fix
  2. jvecchi
    jvecchi Formula Junior
    May 5, 2005
    370
    Sarver, PA
    John M. Vecchi
    I have the same problem. Anyone have any solutions?
  3. OCMIA
    OCMIA Rookie
    Jan 4, 2012
    38
    Orange County, CA
    Chris
  4. Caeruleus11
    Caeruleus11 F1 World Champ
    10,910
    Its a "common" problem. The only fix I am aware of is to replace the entire cover and its mechanism. Sorry I can't be of more help.
  5. ferraripanoz
    ferraripanoz Formula 3
    1,409
    Mark
    Depending on the circumstance sometimes all that needs to be replaced is the damper on the side of the plate for radio. And yes you can buy it separately. If it doesn't fix it, than you do have to get the whole cover.
    SonomaRik likes this.
  6. Muftah
    Muftah Karting
    Mar 3, 2012
    164
    Boston, Ma
    Muftah
    I had the same problem with my 2010 599 HGTE,
    Usually, is due to a broken or missing teeth of the plastic wheel or gear mechanism that controls the open-close motion of the cover.
    I was able to fix mine by changing the plastic wheel - gear mechanism.
    I bought the "tiny" part from Ferrari of New England for $55.00 I believe.
    Good Luck,
    Muftah
    gsholz likes this.
  7. Caeruleus11
    10,910
    Great information. Thank you all.
  8. Condor Man
    Condor Man F1 Rookie
    4,857
    Los Angeles
    Thanks. I am going to try this too.
  9. jvecchi
    May 5, 2005
    370
    Sarver, PA
    John M. Vecchi
    Do you have a part number or something and a source for this? The price I was quoted from a dealer to repair this was astronomical.
  10. Toddston
    Toddston Karting
    Nov 29, 2006
    156
    New York, NY
    Mine too. Was quoted 3 hours of labor to take apart and reassemble. I am not that savvy and Ricambi wants $2000.00 for a new carbon cover.
  11. glob1971
    glob1971 Formula Junior
    442
    Czech Republic
    Same story for me, mechanism broken and door not closing properly - my dealer ordered "a very cheap part" that will be delivered on monday, and problem will be fixed. Conclusion, there is a way to fix the mechanism without changing the whole part.
  12. Muftah
    Muftah Karting
    Mar 3, 2012
    164
    Boston, Ma
    Muftah
    Jvecchi,
    I just saw your post, It has been a while and couldn't find my old invoice.
    Let me know if you still need the part number and description , I am sure I can get all the info from FONE.
    Best,
    Muftah
  13. jvecchi
    May 5, 2005
    370
    Sarver, PA
    John M. Vecchi
    Yep, I could certainly use the info. I appreciate the help!
  14. ferraripanoz
    1,409
    Mark
    It's part number 261198. Any Ferrari dealer should be able to get it.
    Mark
  15. Muftah
    Muftah Karting
    Mar 3, 2012
    164
    Boston, Ma
    Muftah
    #15 Muftah, Sep 23, 2014
    See the Picture below for the Radio cover wheel:
    Best,
    Muftah
  16. Roupin
    Roupin Formula 3
    Oct 7, 2013
    2,167
    Encino
    Roupin
    It seems worth buying one just to keep as a spare.
  17. Toddston
    Toddston Karting
    Nov 29, 2006
    156
    New York, NY
    Many thanks, Mark and Muftah. Funny how a rather insignificant part of the car that when not working properly can cause you so much grief.
  18. jvecchi
    May 5, 2005
    370
    Sarver, PA
    John M. Vecchi
    Yes, thank you. A dealer quoted me $900 for the dumper part. :(
  19. ferraripanoz
    1,409
    Mark
    Which part and how much labor were they quoting you? Seems too high.
    Mark
  20. jvecchi
    May 5, 2005
    370
    Sarver, PA
    John M. Vecchi
    It was the dumper, installed.
  21. ferraripanoz
    1,409
    Mark
    I would say you got over quoted. Like someone was saying they got quoted 3 hours to take apart and reassemble. The part it self should be around ~$50, so in total (labor+part) you are looking at $500-$600.
  22. jvecchi
    May 5, 2005
    370
    Sarver, PA
    John M. Vecchi
    I received my 599 back today. The radio cover is fixed. It turns out that the dumper had been replaced by the previous owner, but had been installed upside down.
  23. Toddston
    Toddston Karting
    Nov 29, 2006
    156
    New York, NY
    Boy, do I hate bringing this up again but the radio cover on my 599 will not stay down after having it successfully repaired last fall. The dealer who did the work informs me that Ferrari now sells an "overhaul kit" and that my cover now requires that kit. Cost? $2100.00 for the kit and about $900.00 for the labor. Can anyone confirm this? And yeah, I know, is the cover that important? But is that really my only option? Thanks for caring.
  24. Wheels1
    Wheels1 F1 Rookie
    3,523
    Grant
    What on earth do you get in a overhaul kit for a radio cover for $2100?
    It would be cheaper to buy one of the new radio's from Ferrari ! Maybe that is why they are doing it?
  25. vaderinc
    vaderinc Formula Junior
    Jul 6, 2010
    531
    Dubai, UAE
    Mario
    Sure sounds like it.
