Ferrari 812 Superfast Tech highlights | FerrariChat
Discussion in 'F12/812' started by Caeruleus11, Mar 7, 2017.
  1. Caeruleus11
    Caeruleus11 F1 World Champ Rossa Subscribed
    Jun 11, 2013
    11,625
    I thought it might be interesting to discuss the new innovations. I made some screen grabs of the videos for discussion purposes...
  2. Caeruleus11
    Jun 11, 2013
    11,625
    1. Torque. The F12b has ever so slightly more lower torque, but I doubt we would notice it. However, the torque keeps rising with RPMS until a little over 7,000. I think this is remarkable as usually the torque peaks and then falls earlier. This is 1,000 RPM better than the F12b. I think this means you will feel a relentless surge of power..
    2. HP. And as the torque falls off, the HP just keeps throwing you forward. Again, remarkable.
    I can just imagine how this would feel, like the F12b, but even more so. Its almost unbelievable that there is so much power and you can feel it building as you rev the motor. Most motors are tuned for daily torque and then they fall off. The F12's V12 isn't your typical motor and this is another step above that!
  3. Caeruleus11
    Jun 11, 2013
    11,625
    Exactly as we would have expected. Hard to believe there is room for this much improvement, but apparently the numbers say its there.
  4. Caeruleus11
    Jun 11, 2013
    11,625
    Here we have something really fascinating. Notice they highlight the EPS (electric power steering) and the SSC (slide slip control hardware of e-diff, rear steer, F1 Trac). If I understand this correctly, they are using the electronics to send you a hint via heavier steering feel that you are getting closer and closer to the edge of adhesion. I’m very curious to see how this is received. It sounds like the kind of thing that will benefit novices but the seasoned drivers might not like it (maybe only at first). And have a look, for oversteering they are hinting they can help you out- perhaps by slightly adjusting the steering to get the desired result?! Another thing that would probably upset purists, but benefit average drivers.
  5. Caeruleus11
    Jun 11, 2013
    11,625
  6. Caeruleus11
    Jun 11, 2013
    11,625
  7. Solid State
    Solid State F1 World Champ Owner Rossa Subscribed
    Feb 4, 2014
    10,591
    Maximus Decimus Meridius
    Thanks for this thread. The 812 (really should be 712 on this side) has continuously variable intakes. This is something that only the Laf has and a distinct improvement over the tdf. The video also says that 75% of the engine is new. I really like what I see here. It may only have 57 more hp than F12B but I bet you can feel it especially with the new gear ratios and increased torque from 6K to 7K. IMO there's enough headroom in this engine for the Special version to be mind blowing.
  8. Maximus1973
    Maximus1973 Formula 3
    Oct 29, 2016
    1,541
    Now if Lambo can claim the Huracan Performante has the new Ring record, the 812 should smash it to pieces with it's similar aero designs and increased power output...... as suspected the design of the 812 is indeed a form follows function aproach. The vents and ducts are there for a reason. Some might argue they make the design more tacky, but this is progress on a performance level.
    Does anyone actually believe the Lambo's Ring time!?
  9. Maximus1973
    Oct 29, 2016
    1,541
    Absolutely. Good choice for an actor.
  10. Maximus1973
    Oct 29, 2016
    1,541
    Even more race engine inspired performance. This will add even more drama when pushing the 812. Making it not only feel faster ad you push it, it actually does go faster. How cool is that! Torque climbing equally with hp is an impressive technical feat.
  11. carlom001
    carlom001 Formula Junior
    Jul 9, 2010
    338
    and unlike the TDF, there is no extraction of air via rear wheel arch vents
  12. F12JAJ
    F12JAJ Formula Junior
    Apr 24, 2016
    568
    California
    Jerry
    It is truly hard to believe that there was ANY room for improvement over the F12B but I guess the Maranello boys found it and really applied their advance at every significant level...torque, power and aerodynamics. Having said all of that I still love with my F12B.
  13. -CD-
    -CD- F1 Rookie Silver Subscribed
    Jun 7, 2005
    3,839
    near the Nürburgring
    Christian
    Absolutely? Sure? I would say this absolutely not Clive Owen...
  14. italiafan
    italiafan F1 World Champ Silver Subscribed
    Jul 19, 2006
    16,121
    Stickbones Swagglesmith
    I think those pictures are very interesting, but then again I also thought the same of the aerobridge too. :)
  15. Garretto
    Garretto F1 Veteran
    Sep 3, 2003
    5,075
    Bilbao, Spain
    Rodolfo Di Pietro
    How convenient, every aero-gadget in the 812 increases downforce and reduces drag :( Most often than not, in reality, the increase of downforce comes at the cost of an increased drag.
    I'm definitely not buying the rear arch by-pass, I'm sure the aero effect of this is close to zero. And what about the rear spoiler drawing, so convenient also, are we supposed to believe the air does that, actually?
    Vanes, front opening ducts and diffuser, yes, I buy their functionality, but the rest...
  16. boondocksts
    boondocksts Rookie
    Apr 30, 2004
    27
    SW USA
    Thanks for posting, do you have a link to the video?
  17. Caeruleus11
    Jun 11, 2013
    11,625
    You're welcome. Videos:
    Note to Ferrari, I could not find these videos on your official channel; otherwise I would have posted the links. Heres where I found the following
    812 Superfast Trailer:
    https://www.youtube.com/watch?v=NXU2VYwZWBM
    A quick note- some people pointed out how absurd it seems that he is out running a rain storm and then a massive wave; but after watching this a few times (I'm too eager to see the car than think about story) its clear to me he is sitting in the car and either imagining that it is so powerful it can do all those "heroic" things, OR, he is somehow teleporting to another dimension (the 12th?!) where he can then do those things... Notice how you see the sky tear apart a little before and after?? It reminds me a little about a new show on TV called "Legion". Anyway, putting that aside, the car looks so much better to me when its in motion than the pictures so far and the sound is superb!
    I like that they cast Clive Owen in there. I think he was great in other car based features.
    So welcome to the 12th Dimension... no pesky V8s here! :)
    Engine:
    https://www.youtube.com/watch?v=Hkc2PYCtQA4
    Aerodynamics:
    https://www.youtube.com/watch?v=WI2sixAADzQ
    Vehicle Dynamics:
    https://www.youtube.com/watch?v=j1z5KvJ2Wv8
  18. Garretto
    Garretto F1 Veteran
    Sep 3, 2003
    5,075
    Bilbao, Spain
    Rodolfo Di Pietro
    Huh? Not Clive Owen :D
  19. Arvid
    Arvid Formula Junior
    May 28, 2012
    668
    Norway
    Arvid Andersson
    +1
  20. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,435
    Bournemouth, UK
    Excellent topic! Thank you Caeruleus11!
    This is what makes the 812 (and every Ferrari) great, not the mellow design or the soft leather inside.
  21. italiafan
    Jul 19, 2006
    16,121
    I guess my question is: if their design brief says sacrifice some elegance to beef up the aero and technology for high-speed performance, costing north of $400K in the process, will it circle a track faster than a $100K Corvette Z06?
    I'm guessing it won't.
    Design, beauty, materials do matter.
  22. C4YES
    C4YES Formula Junior
    Apr 7, 2008
    992
    Orange County, CA
    Todd
    Thanks for posting. The aero pics are very interesting.
  23. Traveller
    Traveller F1 Veteran
    Apr 10, 2009
    6,323
    Tim
    Well you have to say they have managed to keep to one tenet of LDM's ,which was no wing, by creating an almost virtual rear wing. I wonder when that will also be dumped in the search for ever more downforce?
    Thanks for posting and whilst clearly I am no aerodynamicist, but does any of this appear really ground breaking and do we have any figures to compare?
  24. boondocksts
    boondocksts Rookie
    Apr 30, 2004
    27
    SW USA
    Thank you!!
  25. furmano
    furmano Three Time F1 World Champ
    Jul 22, 2004
    32,215
    Colorado
    Furman
    The electric steering could be a game changer. Maybe the steering will get some more road feel back.
    -F
