Ferrari backfired died and wont start | FerrariChat
Discussion in 'Technical Q&A' started by musicman102357, Aug 16, 2008.
  1. musicman102357
    musicman102357 Karting
    Apr 16, 2005
    155
    Hello,
    Here is what happened to my Ferrari 328 today:
    It started up fine, almost immediately after leaving my driveway the car started to sputter and felt like it was going to just shut off. It was like the car was not sparking right and it seemed like it wanted to stall. I was only down the street from my house so I turned the car around and drove it into the garage. I turned the car off, and tried to start it again. It would not turn over, all I hear was a whoosh sound. The starting issue is not battery related. I just had the Major service done 300 miles ago. I also had the Cam shafts replaced as I had a major oil leak problem. The week before when I took the car out there were no issues at all. The time before that it was sputtering a bit but once it warmed up it was fine.
    Does any one have an idea what this might be ?? Fuel pump maybe ??
    M
  2. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Uhmmmm, what kind of whoosh sound?
  3. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    oh man... it doesn't sound good...sorry to hear about your trouble...
    I don't EVEN want to hazard a guess...because everything I might guess is ... well... not good....
    But it could be less serious... hopefully, anyway...
    Best of luck, and let us know...enquiring minds want to know.
    Mike in Kuwait
  4. carb308gtb
    carb308gtb Karting
    Oct 20, 2006
    188
    Svezia
    Patrik
    It might be the starter that dont engage and spinning free, If so, then your starter needs some lube.
  5. musicman102357
    Apr 16, 2005
    155
    Sounds like a woosh of air. The car did backfire before the trouble started. I am lucky I was not far from home otherwise it would have needed a tow.
    When I was sitting I could get the car to idle up but once I let up on the the gas pedal the car acted like it would stall.
    I am going to guess that it could be a bad fuel pump.
  6. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Did it backfire out the exhaust, or "pop" through the intake? If it was through the intake, it might have simply blown off the boot.
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    You have a 3.2, yes?
    As suggested, ensure no air or other leaks at hose connections.
    Check that you have spark on both sides.
    Check the O2 protection relay for the K-jetronic in the trunk. It's the relay with the fuse on it: check the fuse, remove the relay and shake it. If it rattles, it's broken (This is a high probability)
    Remove the air filter - with the key on, depress the big round air mass sensor plate right there - once depressed, you should hear the fuel pump come on.
    This should get some basics looked at.
  8. thecarreaper
    thecarreaper F1 World Champ
    18,068
    Savannah
    um, its nice to try to help, but you do not lubricate starters.
  9. thecarreaper
    18,068
    Savannah
    did you buy fuel last time on the way home? could it be bad gas?
    did you check to see if you have fuel pressure? spark?
    there are several things you can eliminate, if you know what IS working.
  10. musicman102357
    Apr 16, 2005
    155
    It looks like it was the O2 protection relay that was the culprit. The wiring was the problem. A sigh of relief on my part!! Thanks to everyone who offered advice and especially to SNJ5 for figuring it out.
  11. Sigmacars
    Sigmacars Formula 3
    1,218
    where is this relay located in the trunk?
  12. musicman102357
    Apr 16, 2005
    155
    #12 musicman102357, Aug 20, 2008
    I am not sure where it is exactly, I brought the car to Boston Sports and mentioned that I thought the issues might be that relay. That was where they looked first and found the problem. I believe you have to pull out a couple of panels in the trunk to get to it. I also noticed that someone here with a Mondial had the same issue I had.
  13. msouza
    msouza Formula Junior
    Mar 14, 2005
    292
    Tennessee
    Milton Souza
    It's located in the trunk, on the passenger side. Remove the carpet, and you you see the panel. Remove all 4 10mm bolts, and flip the panel up.
  14. DMC308
    DMC308 F1 Rookie
    Aug 19, 2006
    2,573
    Seattle/Noosa
    D
    I'm gonna need some pliers and a set of 30 weight ball bearings, and wash that windshield...look at that filth and muck...
    http://www.youtube.com/watch?v=J5j4iOjCLWs
