Ferrari Battery Tender (Ctek US 800) Problem | FerrariChat
Discussion in 'Technical Q&A' started by mjz, Dec 22, 2012.
  1. mjz
    mjz Karting
    Aug 3, 2007
    173
    Houston, Texas
    Michael
    I have a 2007 F430. I put a new Optima Red Top in it to replace the original Battery a year ago. I connected the Ferrari supplied battery tender to keep the battery charged when not in use.
    Lately the battery tender started showing the red 'charge' light more and more - rarely going to green. I suspected something was up - but the battery was too new and started the car just fine so I paid little attention.
    This morning, the car was dead, the tender had a faint charge light (not bright as per normal). When I checked the voltage, the Optima battery was at 5.0 volts and quite dead. Nothing was left on (no lights, etc.) and the tender should have handled that anyway.
    I took the battery to the store where I bought it and they re-charged it and told me the battery was fine, just dead. It took the charge and came roaring back - full cranking amps of power.
    I suspect that the Ferrari/Ctek supplied battery tender failed and discharged my battery.
    Anyone experience this? I need to find a new and proper battery tender for long storage. The one from Ferrari I suspect has failed - although I don't know why. Battery Tenders are fairly bullet proof.
    Any ideas or experience ?
    thanks
  2. red3555gtb
    red3555gtb Formula 3
    1,356
    Woodbridge/Ontario
    Rocco
    I had the same problem with the CTEK US 800, I replaced it with the CTEk 3300 with better results .
  3. frogwo
    frogwo Formula Junior
    Jan 15, 2005
    283
    Same issue. The Ctek trickle charger kills the battery when it goes bad. In this instance the Ctek trickle charger usually makes a clicking sound when it is bad. It will drain the battery. This is what happened when the early design Ctek trickle charger supplied by FERRARI went bad. If you accidentally due not plug in the Ctek trickle charger on the 120 Volt side and leave it plugged in on the 12 Volt / car side it will also drain
    the battery.
  4. JCR
    JCR F1 World Champ
    10,773
    H-Town, Tejas
    You need to google, "optima battery problems".
  5. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    +1
    I have had this happen. Also on another occasion the Ctek charger was not big enough to supply the residual load of clock, radio etc, and decided to completely discharge the battery instead of charging it.
    On both occasions this destroyed the battery. These are badly designed. For something which claims to be the most advanced battery charger blah blah, this is a basic flaw. They should be designed to deal with a simple user mistake of this kind.
  6. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I have uses an Interstate Battery Tender on my BB512i with an Optima Red Top since 2001 and it still works as new.
  7. mjz
    mjz Karting
    Aug 3, 2007
    173
    Houston, Texas
    Michael
    It does seem it was the Ferrari supplied Ctek US800 that was the problem.
    I was able to recharge the Optima red top to full power despite it being drained to 5.0 volts.
    I then hooked up a Ctek 7002 battery tender that has a specific setting for AGM batteries. It quickly put the battery through the cycles and completed by lighting up the green LED for maintenance mode. It's been this way for a few days without any issue.
    When I went to start the car - it started instantly with full, fast cranking. I had forgotten what that was like. The battery was probably under stress for quite some time from the Ctek US800 model.
    I'd like to use the original plug if possible. Anyone know where I can get a matching "male" plug adapter to fit the 430's original battery charge connection? I connected the new Ctek's pig tail, but it is not as convenient as the plug by the door.
  8. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    I had the same problem. I just cut the wires and spliced it into the new tender.
    Art
  9. HH11
    HH11 F1 Rookie
    3,338
    Ironic and timely for me as well.
    Same car (even the year), same problem, same trickle chargers.
    Ferrari one died on me so I bought the 3300 after reading some threads.
    Is it best to just attach the red and black clamps to the battery leads or try and splice the cable and hook up the original plug? I had thought about splicing it but didn't want to ruin it. I'm fairly good with things like that but thought I'd ask first.
  10. red3555gtb
    1,356
    Woodbridge/Ontario
    Rocco
    With the battery in the 328 under the spare wheel, I had no choice but to splice the cable and add an extension to it, as the CTEK 3300 supplied cable is way to short.
  11. ONEOFEW
    ONEOFEW Formula Junior
    Jan 19, 2006
    834
    LA
    Steve
    CTEK 3300 or 7200 come with a set of alligator clamps and a set of eyelet terminals, it's best to connect the eyelet terminals to your battery poles and use the quick disconnect of the CTEK. There is no need to splice wires to use the OEM plug or the alligator clamps.
    I had the exact same issue with my OEM CTEK, it drained my original Odyssey, and a MTP-91.
    When I pulled my dead Odyssey out it had 9.8V, CTEK 7200 brought it back to life within 24 hours, afterwords I let my battery rest for a day with nothing hooked up, it registered 13.6V, I load tested it twice 1000CCA for 10 sec, it held at 12.8 first, 12.6 second time around. I put it back in the car, connected the eyelet terminals of the CTEK 7200 and now I'm using the quick disconnect.
    One thing I noticed, both the OEM unit as well as the 3300 will light up as if they are charging if the battery terminals are connected and the wall plug is not plugged in. 7200 doesn't do that if you forget to plug it to 120V, nothing lights up, also automatically recognizes it's an AGM battery, no need to select type of battery unlike the 3300.
  12. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    I spliced mine. Made it easy to use, and the old one was broken, so it had no value anyway.
    Art
  13. conscom
    conscom Formula Junior
    Jan 6, 2008
    467
    Vancouver BC Canada
    Gary
    Just took delivery of my 2007 F430 which included a Ferrari battery Maintainer made by CTek Model Xs 800. it belongs in the garbage. 800 ma charge rate is useless. I've finally hooked up my Battery Tender which charges at 1,25A and is doing the job. Just throw the Ctek away. Overrated for the price!
  14. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Someone figured it out how to wire quite a while back. I'll see if I can find the post...
  15. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    #16 ar4me, May 8, 2014
  16. F456 V12
    F456 V12 F1 Veteran
    5,154
    Coto de Caza
    Christian
    I had a Ferrari supplied Ctek charger with my 360 and it never worked well, a real POS. I was just too lazy to get it swapped out - under warranty, so I went and got something that worked - Deltran trickle charger.
    Save yourself a lot of frustration, spend $70.00 and forget about it.
    BTW, hookup behind the drivers seat, easy install, take about 15 minutes, most of which is taking the screws out and removing the panel.
    MB
    http://batterytender.com
  17. Caeruleus11
    Caeruleus11 F1 World Champ
    11,428
    Its not that CTek is a bad company, but the 800 tender can only supply 0.8A and thats not enough. The 3300 can do 3.3A and the 7002 can do up to 7A. The 7002 is probably overkill but it has the most advanced tending modes. The Deltrans are OK but the CTeks are far more advanced. Its just that you need to pick the right tool for the job and the fault here lies with Ferrari for supplying one not up to the task.
  18. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    it's not the fault of the charger !... the 800 Cetek charger is designed for small capacity LEAD ACID ( std wet cell ) batteries up to 42AH capacity... ("RTFM"... read the manual )
    there is more to it than the voltage marked on the charger... the "older" style chargers are not able to meet the charge profiles of the newer batteries... using an "old style" charger on any newer construction battery - non wet cell is a slow death for the new battery... since the batteries will not be charged to full capacity... best to get a new smart charger that is designed or is selectable for the type of battery being charged... this applies to ALL chargers designed to be used with wet cell batteries...
    don't trash your "old" Cetek as it may not be damaged and could be working fine, when only used on wet cell batteries
