Ferrari California Engine light keeps coming on | FerrariChat
Discussion in 'California/Portofino/Roma' started by Nabster, Apr 19, 2013.
  1. Nabster
    Nabster Rookie
    Apr 14, 2013
    1
    Hi there to all the ferrari drivers out there. I recently became a ferrari owner for the first time back in june 2012. i bought a 2011 California ferrari with 1500 kms on it in vancouver canada. Within the first time two months I was in the shop with the ferrari engine light coming on and telling me to take to dealer. The first time was when I ran out of gas...my stupidity I was used to driver a Sl 500 before which once the gas light came on it would take forever for it to run out...anyhow took it in they corrected the problem. It happened again for no reason, and now its on again. It is such a hassle to take it in everytime that nothing seems to be wrong with the car except for the bloody light??? any thoughts...
  2. RickLederman
    RickLederman F1 Rookie
    2,836
    Swanton Ohio
    Rick Lederman
    I'd take it back to see what the computer says is causing the light to come on. Their software is pretty good at telling you what is happening. I've had two Cali's with over 45,000 total miles and no engine light problems.
    Ran out of gas ... wow I would be very careful about that, modern fuel systems really don't like that.
    Rick
  3. TheMayor
    105,139
    Vegas baby
    Most likely a software update is needed. What happens is if it gets even a single misfire, it sends the signal to check the engine.
    Both my 458's did this and both were corrected with a software update.
  4. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #4 4th_gear, Apr 19, 2013
    I was told you should never run out of gas with a fuel-injected car. Do not try your luck in that scenario.
    Fuel injectors need fuel to cool and lubricate themselves with. If the tank runs too low or dry, the injectors can damage themselves. I think the "check engine" light is a catch-all for a number of possible sensor codes. The dealer garage can scan the codes to narrow down the cause(s). I would not tell them to just clear the codes.
    P.S. Nearly forgot, I'm not sure how the fuel pumps work in the California but another danger of drying out your gas tank is the fuel pump. My E30 BMW had 2 fuel pumps, one near the engine and one actually in the fuel tank. The one in the tank was definitely cooled by the fuel - can't recall if the other one was as well. But one consequence of running the car on a near-empty fuel tank was that the pump in the tank could ruin itself if it wasn't immersed in fuel. It's nasty to replace the pump in the fuel tank. The California probably has a different setup but the E30 BMW was also not a fossil or unsophisticated by any stretch of the imagination.
  5. TheMayor
    105,139
    Vegas baby
    This also is true. Direct injection has its quirks. I was told never to rev the engine and shut it down. You need to let it settle or it will foul the plugs.
  6. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    the biggest risk with a fuel injected car, especially a direct injection, is the high pressure system and particularly the pumps. If they run dry and spin up, they can overheat and/or have other bad things happen if they spin dry for a period. In a modern Fcar, if you run dry (and ignore the low fuel light), the car should go into mild limp mode; when you actually run dry it would detect low fuel pressure, then engine running too lean, then drop cylinders, and eventually it will shut itself off. (ask me how I know)
    As for the CEL, the dealer can read the code, if it's a specific fault they can address it. In most cases, they can clear a code and it will not reappear, some codes will clear upon reboot/restart, some can be cleared with the computer (higher criticality), some may require an actual repair or replacement (eg. bad O2 sensor or thermocouple on a 430).
    The alarm software on the modern cars is very conservative (i.e. tries to warn you and save the car) and also very sensitive (one transient fault and it alarms). If your battery ever dies, when you try to start it up it the dash will likely glow like the Vegas strip...
    Please keep us posted, tribal knowledge on issues is valuable.
