News
Ferrari culture vs aftermarket parts
Discussion in '360/430' started by Felix Yuen, Nov 8, 2020.
  1. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    84
    Cocoa Beach, FL
    Aeron F
    Wow, very interesting circumstance. That’s the first I’ve heard of a head gasket failure on a 360. It sounds like you really rebuilt it the right way.
    dbdreams likes this.
  3. dbdreams
    dbdreams Karting
    Nov 6, 2003
    166
    Hayden, Alabama, USA
    David W. Burnett, Jr.
    Everyone including my mechanic in the Ferrari know says they have never heard of a head gasket blowing before but it happened to me last Thursday.
  4. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    84
    Cocoa Beach, FL
    Aeron F
    That’s such a bummer. What is the mileage on yours?
  5. dbdreams
    dbdreams Karting
    Nov 6, 2003
    166
    A little less than 38k miles
  6. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    84
    Cocoa Beach, FL
    Aeron F
    Did your car previously have a heat exchanger failure? Mine failed around 40k miles, and I’m wondering if that could be a cause of overheating and warped heads. Fortunately my heat exchanger issue was fixed before any major damage happened, but I wonder if the two issues have any correlation.
  8. dbdreams
    dbdreams Karting
    Nov 6, 2003
    166
    I am not really sure, I just got the car August 15, 2020 and had only put about 2k miles on it since then with no issues with overheating
  9. Felix Yuen
    Felix Yuen Rookie
    Sep 3, 2018
    33
    Felix Yuen
    great, now with a front end $19k damage, how much should it reflect in the price ? $5000 ? $10000 ?
    I guess its kinda hard to put a number to these things.
  10. Skidkid
    Skidkid F1 Veteran
    Rossa Subscribed Owner
    Aug 25, 2005
    6,650
    Campbell, CA
    John Zornes
    You are in the right range.
  11. armedferret
    armedferret Formula Junior
    Mar 24, 2018
    430
    Mark
    Ultimately it depends on the buyer. If someone is looking for a 'driver' and a bump on the front end that didn't damage anything structurally (aesthetic/cosmetic damage only) is all that happened, it probably won't affect value as much. Of course that's assuming a car that was already a driver's car, and not a low-mileage "collection" car.
    imahorse likes this.
  13. ckrescho
    ckrescho Rookie
    Nov 21, 2020
    3
    Christopher Kreschollek
    I've only heard of a 3 angle valve job.
  14. armedferret
    Mar 24, 2018
    430
    Mark
    I came up in the 90s sport-compact scene, and 5-angle valve jobs were fairly common among the machine shops back then (and i would imagine significantly further back than that, but I don't have personal knowledge to make a hard-and-fast statement); however, it was pretty well known that outside of seriously high performance applications, a 3-angle (which was significantly less money, and when you're in your late teens/early 20s that's a factor ;) ) would provide more than enough gains in sealing and flow that most guys didn't opt for the full 5. typically those who did were extracting every tiny bit of HP from a high-compression, high-revving NA build.
    hence.... ;)
    ckrescho likes this.
  15. ckrescho
    ckrescho Rookie
    Nov 21, 2020
    3
    I suppose it's just the tool used in cutting the valves.
    armedferret likes this.
  16. armedferret
    Mar 24, 2018
    430
    Mark
    #38 armedferret, Nov 21, 2020
    Almost. ;)
    It's the valve seat that's being machined, not the valve itself.
    Honestly, a DIY type could get 95% of the effect of a fresh valve job (provided no damage, of course) by throwing some lapping compound on the perimeter of the seat face around the valve head, holding it firmly against the seat, and spinning it. Sort of like lapping bolt lugs to a rifle receiver.
    if the valve or the head have suffered any damage at all, though, it's probably wise to "while you're in there" and replacing parts already, go ahead and cut out the old seats, install new ones, and do a valve job. it'll be in the machine already getting milled for flatness anyway.
  17. Need4Spd
    Need4Spd F1 Veteran
    6,085
    Silicon Valley
    This. But the overall condition of the car and service history is more important, unless I don’t like the mods and it would be expensive to undo them. Bodywork mods are the worst. They’re costly to undo, and only cosmetic. I’d pass on any car that had anything more than a swap to an OEM challenge rear grill.
